Logitech G933 Artemis Spectrum Wireless 7.1 Surround Gaming Headset
Quicklinx: DQWRWS00 Mfr#: 981-000599
This headset is made with hybrid mesh materials that provide the audiophile-like performance gaming fans have been demanding. From your favorite music to expansive game soundtracks, the headset delivers both clean and accurate highs as well as a deep rich bass that you would expect from premium headphones.
  • Pro-G audio drivers for superior performance
    Patent pending advanced Pro-G audio drivers are made with hybrid mesh materials that provide the audiophile-like performance gaming fans have been demanding. From your favorite music to expansive game soundtracks, the Pro-G drivers deliver both clean and accurate highs as well as a deep rich bass that you would expect from premium headphones. Experience incredible 7.1 surround sound with Dolby or DTS Headphone:X Surround Sound, creating lifelike in-game spatial awareness, allowing you to clearly hear enemies sneaking around or special ability cues
  • Multi-Platform Compatibility
    G933 Artemis Spectrum works with PC, mobile, home theater devices, and game consoles, including PS4 and Xbox One . One headset for all your devices lets you take G933 Artemis Spectrum from your gaming rig to your gaming console and your mobile devices. You can even connect your home theater to the USB-powered wireless mix adapter and listen to TV shows, music, or movies wirelessly without disturbing the people in your home
  • Customizable RGB lighting and tags
    G933 Artemis Spectrum has two customizable lighting zones: The light strip and logo. Each zone can each be programmed to different colors or effects, or can be synchronized. Adjustable RGB lighting lets you select from approximately 16.8 million colors. Use Logitech Gaming Software to set the glow pattern or color for your environment. Add a set of backlit custom tags to enhance your look even further. Download Logitech Gaming Software Learn more
  • 2.4GHz wireless
    G933 Artemis Spectrum Wireless Gaming Headset gives you the best of both worlds, with the option to play wirelessly or wired. Play lag-free on 2.4GHz wireless for up to 12 hours per charge, without lighting, or 8 hours, with default lighting. Alternatively, the 3.5mm analog input on the headset gives you the freedom to play wired without using battery power
  • Programmable G-Keys
    Assign custom commands using Logitech Gaming Software on the three programmable G-keys for a seamless gaming and media experience. Set custom controls to control your audio profiles, skip to the next song, activate push-to-talk communication, trigger instant in-game command combinations, and more. Download Logitech Gaming Software
  • Custom sound profiles
    Use Logitech Gaming Software can to program the audio equalizer and pre-set audio preferences for music, games and movies. Customize audio settings and create personal sound profiles for each game you play. Listen to your media just the way you like it. Download Logitech Gaming Software
  • Multi-Source Audio Mixing
    No more game interruptions from incoming calls. Answer the call while you continue your game without pausing or taking your eyes off the action. Use the USB mix adapter to add up to two additional devices. The audio from additional devices is mixed with the PC audio
  • USB-Powered Mix Adapter
    Combine an analog input on the wireless mix adapter with a powered USB port to make your analog audio devices wireless. When you plug in the USB Mix Adapter to a powered USB port, it will transmit mixed audio from the USB input and the integrated 3.5mm input to your headset, even if your USB port does not support USB audio
  • Crystal-clear communication
    Ensure you are heard with a crystal-clear noise-cancelling boom mic. The boom has an indicator LED so you know when your microphone is on mute. When not in use, the noise-cancelling boom mic can be folded back into the headphones and is nearly invisible. G933 is travel-ready with an included mobile cable and secondary inline mic for mobile devices when you don't want a microphone boom in your face
  • Long-term Comfort
    G933 Artemis Spectrum is designed for long gaming sessions. New sports mesh materials used in the ear cups and headband are soft and breathable for maximum comfort. Over-the-ear ear cups on G933 Artemis Spectrum are designed to fit around most ears without applying pressure on soft tissues. To keep your headset clean, the ear cups can be removed from the headset and washed
Logitech Gaming Headset G933 Artemis Spectrum - wireless headset system
Wireless headset system - 7.1 channel - wireless
Recommended Use
TV, Game console, phone, computer
Additional Functions
LED lights, adjustable RGB lighting
Headphones Form Factor
Full size
Wireless
Sound Output Mode
Surround Sound
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 107 dB
Impedance
39 Ohm
Microphone
Boom
Controls
Remote control
18 cm
19 cm
9.4 cm
374 g
Recommended Use
Max Operating Distance
20 m
Audio Output
Full size
Wireless
Sound Output Mode
Surround Sound
Frequency Response
20 - 20000 Hz
Sensitivity
107 dB
Impedance
39 Ohm
Diaphragm
40 mm
Microphone
Boom
Frequency Response
100 - 20000 Hz
Audio Input Details
Cardioid (uni-directional) - 100 - 20000 Hz
Remote Control
Controls
Remote control
Wireless Link
Transmission Range
20 m
Connector Type
USB (4 PIN USB Type A) , Headset (mini-phone 3.5 mm 4-pole) , Headphones (RCA x 2)
Wireless receiver
Cable Details
Headset cable , Mini-phone 3.5 mm to RCA cable , USB cable
Headset battery rechargeable
Run Time (Up To)
12 hour(s)
