Logitech G923 TRUEFORCE Racing wheel for PlayStation and PC
Quicklinx: GV3KWS00 Mfr#: 941-000150
Type: Wheel and pedals set
Wired / Wireless: Wired
Compatibility: PC, Sony PlayStation 4
10 In Stock
£266.66 ex VAT
£319.99 inc VAT
Express delivery Order within the next 5 hours for delivery tomorrow
Meet the next generation of racing wheels. The award-winning Logitech G design is reengineered to dial into your game physics, delivering unprecedented realism. Feel the pistons pumping, the gravel crunching, and every shift, drift, and hairpin turn like never before.
  • NEXT-GEN SIMULATION
    Our latest innovation in force feedback technology connects directly to in-game simulation engines and physics to produce higher fidelity, real-time responses. The feedback frequency range is also increased for dramatically improved detail and realism compared to previous generations. TRUEFORCE and advanced features require game integration. Visit logitechg.com/support/g923-xb1 for a complete list of supported games
  • CLOSED-LOOP MOTOR CONTROL
    The right current means the right torque. G923's advanced firmware monitors all the current flowing through the wheel motors, continuously adjusting voltage to match outputs from game physics. By going beyond default settings, G923 delivers pinpoint accuracy and unprecedented realism
  • MORE TRACTION. LESS SMOKE
    Get off the starting line cleaner and faster with a programmable dual clutch launch assist in supported games
  • ON-WHEEL GAME CONTROLS
    Complete Xbox Series X|S, Xbox One, PS5 or PS4 controls are built right into the steering wheel. No matter how you race, every command is directly at hand
  • PROGRESSIVE BRAKE PEDAL
    More responsive, more accurate. The progressive spring mimics the performance of a pressure-sensitive brake system for a real racing experience. Reposition the pedal faces for heel-toe maneuvers and even more control
  • BUILT-IN REV INDICATOR
    Built-in colored LEDs show your RPM range in supported games. See when you're redline-ing-right in your line of sight. TRUEFORCE and advanced features require game integration. Visit logitechg.com/support/g923-xb1 for a complete list of supported games
  • Shift Into Overdrive
    To take the racing simulation experience over the top, add the realism of a dedicated shifter. With a short-throw feel in a 6-speed "H" pattern shifter with push-down reverse, the Driving Force Shifter from Logitech G is a driving companion you won't soon forget
  • CUSTOMIZE WITH G HUB
    Take full control of your rig. Adjust wheel sensitivity, force feedback levels, and button customization via powerful G HUB Gaming Software for PC. Download at logitechG.com/downloads Custom-build multiple profiles for any game and application
Logitech G923 - wheel and pedals set - wired
Wired
Wired
USB
Game Controller (1st) Details
Wheel
Controls
PS button, A button, B button, X button, Y button, D-pad, L1 Button, L2 Button, L3 Button, R1 Button, R2 Button, R3 Button
TRUEFORCE feedback, 24-point selection dial, LED indicator, programmable buttons, 900° wheel rotation
Game Controller (2nd) Details
Pedals
Controls
Foot pedal
Brake pedal progressive resistance, carpet grip system, auto-calibration
Microsoft Windows 7 / 8 / 8.1 / 10
Power adapter
Compatibility: PC
Compatibility: Sony PlayStation 4
Brand: Logitech
