Logitech G920 Driving Force Racing Wheel
Quicklinx: DQW2WS00 Mfr#: 941-000124
Type: Wheel
Wired / Wireless: Wired
Compatibility: Microsoft Xbox One
49 In Stock
£246.68 ex VAT
£296.01 inc VAT
Feel your tires on every turn and type of terrain, sense under- or over-steer drifting. Powerful dual-motor force feedback realistically simulates force effects for precision response.
Driving Force handles the stress of racing action and is built for long-lasting reliability. Solid steel ball bearings in the wheel shaft and stainless steel paddle shifters and pedals make G920 the long-distance race wheel. It's covered in high-quality, hand-stitched leather, with the look and feel of a high-performance racecar wheel and it gives you a more comfortable, durable experience.
Helical gears are modeled after gears used in automotive transmissions to reduce unwanted noise and vibration. Anti-backlash keeps the wheel and pedals tight, maximizing your control. This steering wheel delivers exceptionally smooth, quiet steering action. G920 Driving Force racing wheel features a long lasting, reliable hall-effect steering sensor, using magnetic fields to sense the position of the wheel.
  • WORKS WITH Xbox One AND PC
    Driving Force is designed for the latest Xbox One console racing game titles. You may never race with a regular controller again after you experience G920 Driving Force. G920 Driving Force also works on PC with select titles using Logitech Gaming Software. Download Logitech Gaming Software
  • Dual-Motor Force Feedback
  • Designed for distance
  • Helical Gearing with Anti-Backlash
    Helical gears are modeled after gears used in automotive transmissions to reduce unwanted noise and vibration. Anti-backlash keeps the wheel and pedals tight, maximizing your control. This steering wheel delivers exceptionally smooth, quiet steering action. G920 Driving Force Racing Wheel features a long lasting, reliable hall-effect steering sensor, using magnetic fields to sense the position of the wheel
  • Easy-Access Game Controls
    Get even more control over your car's setup. G920 Racing Wheel incorporates the D-Pad and console buttons into the wheel so all your controls are right where you can reach them, while the semi-automatic paddle shifters help you execute smooth, accurate gear transitions on hairpin turns and straightaways
  • Responsive Pedal Unit
    Maintain a more realistic driving body position with the separate floor pedal unit with integrated throttle, brake, and clutch pedals. G920 Driving Force lets you comfortably accelerate, brake and change gears with the feel of an actual car. The nonlinear brake pedal mimics the performance of a pressure-sensitive brake system for a more responsive, accurate braking feel. For even finer control, reposition the pedal faces to make heel-toe maneuvers easier to perform. Rubber feet for hard surfaces and a patented retractable carpet grip system help your pedals stay right where you put them
  • Mounts Securely
    Drive fearlessly knowing the wheel won't shift during aggressive maneuvers. The racing wheel mounts securely to your table or racing rig via built-in clamps or screw mounting points. Take your racing to the next level with a Playseat racing simulation cockpit.  Checkout Playseat
  • 900° Steering
    The 900-degree lock-to-lock rotation of the G920 Driving Force means you can turn the wheel around two and a half times, hand over hand on wide turns. It's the same degree of motion as a steering wheel inside a car
  • Steering Wheel Stripe
    Easily see if your steering is dialed in using a visual cue within your peripheral vision. The steering wheel stripe is a visual indicator of which direction the wheel is pointing
  • Works with Driving Force Shifter Attachment
    Complete your racing rig for the most realistic experience. Add the 6-speed manual Driving Force shifter to your racing wheel setup. Click for more information on Driving Force Shifter
  • GAME COMPATIBILITY
    To ensure compatibility, we work closely with game developers to ensure compatibility with our wheels. To see a list of tested games, click here
Logitech G920 Driving Force - wheel and pedals set - wired
Wheel and pedals set
Wired
900° wheel rotation
Microsoft Xbox One
Wired
USB
900° wheel rotation
Game Controller (1st) Details
Wheel
Controls
D-pad, gear shift paddles
Force feedback
Game Controller (2nd) Details
Pedals
Auto-calibration, carpet grip system
Microsoft Windows 7 / 8 / 8.1
Power adapter
Microsoft Xbox One
Type: Wheel
Brand: Logitech
