Logitech G915 TKL Wireless RGB Mechanical Gaming Keyboard
Quicklinx: HX7XWS00 Mfr#: 920-009501
£189.40 ex VAT
£227.28 inc VAT
A breakthrough in design and engineering, now in black and white colorways. G915 TKL features LIGHTSPEED pro-grade wireless, advanced LIGHTSYNC RGB, and high-performance low-profile mechanical switches. Meticulously crafted from premium materials, the G915 TKL is a sophisticated design of unparalleled beauty, strength, and performance, now in an even more compact form factor. G915 TKL. Play the next dimension.
  • COMPACT TENKEYLESS DESIGN
    G915 TKL features the same advanced technologies as the G915-but in a more compact design, providing more room for mouse movement. The USB receiver can be stored in the back of the keyboard for additional portability
  • LIGHTSPEED WIRELESS
    G915 TKL features pro-grade LIGHTSPEED wireless that achieves super-fast 1 ms performance. G915 TKL is also fully functional when plugged in via USB, so you can charge and play simultaneously
  • IMPOSSIBLY THIN
    G915 TKL is a feat of engineering and design. It's incredibly refined, impossibly thin, and built with a no-compromises commitment to performance and feature set. Durable, comfortable, and ready for intense gaming sessions, G915 TKL is truly the next generation of gaming mechanical keyboards
  • FORMATIVE FUNCTION
    The aluminum-crafted volume wheel is precisely tensioned for premium feel and control. Soft-touch profile and media control buttons deliver tactile feedback for easy and intuitive control
  • STRONG AND DURABLE
    Brushed metal surfaces and oleophobic-coated keycaps are designed to minimize fingerprints. A steel-reinforced base gives G915 TKL an unyielding strength to persevere under the most strenuous use
  • LIGHTSYNC RGB
    G915 TKL offers intelligent LIGHTSYNC RGB technology which enables fully customizable per-key lighting across ~ 16.8 M colors. Create your own animations or choose from a selection of preset effects for the most immersive RGB experience. Unify a theme, enhance your gameplay, and extend your gaming setup through your keyboard. Advanced features require Logitech G HUB Gaming Software, available for download at logitechg.com/GHUB
  • INSTANT LIGHTING CONTROL
    Easily change lighting effects and adjust  brightness with onboard controls. Select from seven preset animations by pressing the brightness soft key plus numbers 1-7. Create up to two of your own lighting profiles using G HUB software and save the profiles to numbers 8 and 9
  • FULL SPECTRUM PROGRAMMABILITY
    With G HUB software, you can create an endless combination of light and color effects across your keyboard. Choose your favorite color, create a pattern, or design your own lighting animations with the robust LIGHTSYNC editing tool. Or choose to have it be controlled by your favorite games, audio, or on-screen content. The result is stunning environmental lighting that immerses your gear, and your room, into the experience
  • ENDLESS CONTROL
    Sleek and sophisticated G915 TKL offers a focused, high-performance experience with every feature you need to take total control-like onboard profiles and game mode. Advanced features require Logitech G HUB Gaming Software, available for download at logitechg.com/GHUB Make G915 TKL the command center for your PC
  • Logitech G HUB
    Logitech G HUB gives players complete control over their gear and games. Customize lighting, create macros and much more. Players can fine-tune their gaming gear settings by game, connect to third-party apps like Discord and OBS, and download and share custom game profiles with the Logitech G community
  • 3 ONBOARD PROFILES
    Save up to three different profiles to the keyboard's onboard memory. Easily switch between stored modes using the F1 - F4 keys
  • GAME MODE
    Deactivate any keys that will interrupt or distract you with the centrally-located Game Mode button. By default, Game Mode disables the Windows key. Use Logitech G HUB to customize game mode to disable any keys you don't need
  • REMARKABLE BATTERY LIFE
    Enjoy hours of non-stop game time on a single charge. Battery indicator light on the keyboard and Logitech G HUB will notify you when the battery is low. Fully recharges in under four hours. Keep playing while it's plugged in and charging via micro USB
  • PLAY YOUR WAY
    Make every game more exciting. A fresh new take on gaming gear is here at last. Decades of performance innovation meet fun, vibrant color. Playstyle matters. Choose yours
Logitech Gaming G915 TKL - keyboard - QWERTY - UK - carbon Input Device
Keyboard
Backlit
LIGHTSYNC
USB, Bluetooth, 2.4 GHz
Wireless Receiver
USB Logitech LIGHTSPEED receiver
Wireless
Localization and Layout
QWERTY UK
Hot Keys Function
Multimedia, volume, mute, play/pause, skip tracks
Gaming
Key Switch Type
GL Tactile
Carbon
36.8 cm x 15 cm x 2.2 cm
810 g
Keyboard
Backlit
LIGHTSYNC
Wireless Receiver
Wireless
Hot Keys Function
QWERTY UK
Keyboard Technology
Mechanical
Key Switch Type
GL Tactile
Gaming
Detachable Cable
36.8 cm
15 cm
2.2 cm
810 g
Carbon
Cable Length
1.8 m
USB extender, micro-USB charging cable
Google Chrome OS, Microsoft Windows 7 or later, Android 4.3 (Jelly Bean) or later, Apple iOS 10 or later, Apple MacOS 10.11 or later
Rechargeable
Brand: Logitech
