G703 features LIGHTSPEED wireless technology, the PMW 3366 sensor and advanced button tensioning for incredible responsiveness for competition-level twitch targeting. G703 is ergonomically designed for long-lasting comfort.
LIGHTSPEED Wireless
G703 is equipped with the same wireless technology pioneered by Logitech in the award-winning G900 Chaos Spectrum. With a 1 ms report rate and our end-to-end optimized wireless connectivity, G703 delivers incredible responsiveness for competition-level twitch targeting -
Gaming-Grade Performance
With G703, the game gets better and so do you. G703 is built for gaming speed, accuracy and endurance. With a 1ms report rate whether wired or wireless, G703 is up to 8x faster than standard mice-which means when the mouse is moved or clicked, the response is near-instantaneous -
Elevate Your Accuracy
Become more accurate than you've ever been before. The G703 features the PMW3366 - used by esports pros worldwide and widely regarded as the world's most advanced gaming mouse sensor. Exceptionally precise and consistent, with zero smoothing, filtering, or pixel rounding across the entire (200-12000) DPI range, it gives you the confidence of quicker responses and more accurate targeting -
Ergonomically designed
G703 brings together supreme comfort, quality, and durability in a lightweight, ergonomically designed body. With rubber grips on the left and right sides to give you added control, the G703 Wireless was made to mold to your hand for long-lasting comfort during gameplay -
Adjustable weight system
The included 10g removable weight module gives you options when it comes to tuning the mouse exactly to your preferences. With the weight removed, the mouse weighs in at a lightweight 107g -
Programmable RGB Lighting
Logitech G703 Gaming Mouse can be used directly out-of-the-box, or can be fully configured using Logitech Gaming Software to match exactly to your preferences. Choose from a palette of approximately 16.8 million colors and brightness levels to match your favorite team, personal style, system or environment -
Onboard memory
With onboard memory, you can take your settings with you wherever you go. Save your settings to the memory on the mouse and use your settings on any PC without needing additional software or requiring a log in to use them -
Six programmable buttons
Logitech G703 Wireless Gaming Mouse can be used with preset programming or fully configured to match your preferences. Advanced users can configure the 6 programmable buttons to sequences of clicks and keystrokes to simplify in-game actions and quickly execute complex tasks -
Programmable DPI settings
On-the-fly DPI shifting that lets you program and switch between up to 5 sensitivity settings, from pixel-precise targeting (200 DPI) for sniping, to lightning-fast maneuvers (up to 12000 DPI) for fast 180-degree turns
- Logitech Gaming Mouse G703 - mouse - USB, 2.4 GHz - black
- Mouse
- Connectivity Technology
- Wireless, wired - USB, 2.4 GHz
- Black
- 6.8 cm x 12.4 cm x 4.3 cm
- 107 g
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Optical
- Buttons Qty
- 6
- Movement Resolution
- 12000 dpi
- Performance
- 1 ms response time, 40 G maximum acceleration, realtime sensitivity switching 200 - 12000 dpi, up to 400 inches per second
- Scrolling wheel, rubber side grips, sensitivity adjustment, adjustable weight, built-in flash memory, 6 programmable buttons, ARM 32-bit processor, Pixart PMW 3366 optical gaming sensor, RGB 16.8 millions multi-colour illumination
- Cable Length
- 1.83 m
- OS Required
- Microsoft Windows 7 / 8 / 8.1 / 10, Apple MacOS X 10.10 or later
- 2-year warranty
- Mouse
- Wireless Receiver
- 6.8 cm
- 12.4 cm
- 4.3 cm
- 107 g
- Black
Input Device
- Wireless, wired
- Interface
- USB, 2.4 GHz
- Optical
- Buttons Qty
- 6
- 12000 dpi
- Performance
- Cable Length
- 1.83 m
- 1 x USB - 4 pin USB Type A
- Included Accessories
- USB wireless adapter, charging cable, adjustable weight cartridge (10 g)
- OS Required
- Limited warranty - 2 years
