HERO is a true breakthrough innovation in sensor technology providing revolutionary performance and efficiency. It's the first of its kind to enable high-performance and long-lasting wireless gaming mice.
Next Generation HERO Sensor
HERO is a revolutionary new optical sensor designed by Logitech G to deliver class-leading performance and up to 10 times the power efficiency 1 . With HERO sensor, G603 also delivers exceptionally accurate and consistent performance across the entire DPI range, with zero smoothing, filtering or pixel rounding from 200 to 12,000 DPI. Learn more about HERO sensor -
LIGHTSPEED Wireless
LIGHTSPEED wireless technology features a super fast 1 ms report rate with our end-to-end optimized wireless solution. G603 delivers incredible responsiveness and reliability for competition-level performance. Learn more about LIGHTSPEED -
Advanced Power Management
Quickly switch between HI and LO modes with the flick of a switch. In HI mode, G603 delivers peak performance with LIGHTSPEED 1 ms reporting and up to 500 hours of non-stop gaming. When not gaming, simply switch to LO mode and extend battery life. LO mode reports at 8 ms for up to 18 months of use with 2 AA batteries. 2 -
Connect to Multiple Devices
Dual connectivity with LIGHTSPEED and Bluetooth allows you to connect to and control multiple devices. Easily toggle between the two connected devices with a press of a button -
Ergonomically Designed and Customizable
G603 is built for comfort with an ergonomically-designed, lightweight, contoured body. Customize G603 to achieve just the right weight by choosing to use either one or two batteries-with no impact to performance. You can also choose which side to place a single battery, for custom balancing -
AMAZING BATTERY LIFE
G603 wireless gaming mouse delivers up to 500 hours on 2 AA batteries-twice as long as our previous generation. Even with a single battery the G603 can last through up to 500 matches of League of Legends . When battery is at 15%, both LED status indicator and Logitech Gaming Software will notify you before the critical moment -
SIX PROGRAMMABLE BUTTONS
The G603 wireless gaming mouse can be fully configured to match your preferences. G603 comes with 6 programmable buttons including on-the-fly DPI shifting through up to 5 sensitivity settings. In LGS, configure macros, sequences of clicks and keystrokes to simplify in-game actions and quickly execute complex tasks. Download LGS Now -
Onboard Memory
With onboard memory, you can take your settings with you wherever you go. Using LGS, store your settings in G603 and play on other PCs without needing to install additional software. No login required. Download LGS Now -
Wireless Gaming Desktop
Pair the G603 gaming mouse with the G613 wireless mechanical keyboard to have the complete wireless gaming desktop solution. G613 features advanced LIGHTSPEED wireless, Romer-G mechanical key switches, programmable G-keys, and more gaming features. Learn more about G613
- Logitech G603 - mouse - Bluetooth, 2.4 GHz
- Mouse
- Connectivity Technology
- Wireless - Bluetooth, 2.4 GHz
- 6.8 cm x 12.4 cm x 4.3 cm
- 87 g
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Optical
- Buttons Qty
- 6
- Movement Resolution
- 12000 dpi
- Performance
- Polling rate: 1000 Hz, realtime sensitivity switching 200 - 12000 dpi, 40 G maximum acceleration
- HERO sensor, ARM 32-bit processor, scrolling wheel, LIGHTSPEED technology
- Battery
- AA type
- OS Required
- Microsoft Windows 7 or later, Apple MacOS X 10.10 or later, Google Chrome OS, Android 3.2 (Honeycomb) or later
- 2-year warranty
- Mouse
- Wireless Receiver
- 6.8 cm
- 12.4 cm
- 4.3 cm
- 87 g
Input Device
- Wireless
- Interface
- Optical
- Buttons Qty
- 6
- 12000 dpi
- Performance
- 1 x USB - 4 pin USB Type A
- Included Accessories
- 2 AA alkaline batteries, USB receiver extender cable
- AA type
- Technology
- Alkaline
- OS Required
- Shipping Width
- 4.7 cm
- Shipping Depth
- 13.6 cm
- Shipping Height
- 19.2 cm
- Shipping Weight
- 263 g
- Limited warranty - 2 years
