G602 redefines the laws of wireless gaming. From the pinpoint accuracy of exclusive Delta Zero sensor technology to high durability primary switches to 11 programmable controls, G602 offers true gaming performance. Count on G602 to dominate boss after boss.
Enduring battery life
Play with confidence. G602 sticks by you through game after game with up to 250 hours of power in Performance mode. That's as much as eight times the battery life of other wireless gaming mice, all without compromising gaming grade sensor and connection performance. G602 is powered by two standard AA batteries; optionally remove one battery to adjust its weight and balance -
Wireless gaming technology
G602 delivers a lag-free experience through a 2.4 GHz wireless connection with a 2 millisecond report rate. Unlike Logitech Unifying receivers meant to connect multiple devices, G602 uses the entire bandwidth of a dedicated USB nanoreceiver for gaming-grade, low-latency performance. Position the nanoreceiver for optimal reception using the included extender cable. A convenient storage slot in the battery compartment keeps the nanoreceiver safe for transport -
Achieve great results with the default configuration straight out of the box. Or, make G602 your own. Set up one-button triggers for actions that typically require digging into menus. Put push-to-talk communications in easier reach. Temporarily down-shift DPI for sniping. Reassign any game command or multi-command macro to any one of 11 programmable buttons with optional Logitech Gaming Software (LGS). Store a custom profile on-board for use with any PC -
G602 is our first wireless gaming mouse to feature exclusive Delta Zero sensor optimizations for high-accuracy cursor control, plus battery-extending power optimization routines. Whether flying across the screen or honing in on one pixel, the 2500 DPI sensor responds accurately to your hand movements. The LED-illuminated sensor is designed to go beyond simple eye/hand coordination, diminishing the thinking required to move your character, adjust your scope for sniping, select RTS units, or direct MOBA skill shots -
In-game sensitivity switching
Make the right moves in any game situation. Two easy-to-reach buttons allow quick shifting through up to five distinct DPI settings. Choose from pixel-precise targeting (250 DPI) to high-speed maneuvers (up to 2500 DPI) right when you need them. And while held, the DPI shift command allows you to temporarily use lower sensitivity for tricky FPS sniper shots; instantly return to faster speeds upon release -
Performance/Endurance modes
G602 offers two distinct operating modes. Set the mode switch to Performance and get up to 250 hours of battery life without losing any gaming-grade capabilities. Not gaming? Switch to Endurance mode and extend the battery life even farther, up to an impressive 1440 hours. The active mode is clearly indicated on top of the mouse – blue for Performance, green for Endurance, and blinking cyan when power finally runs low -
Intuitive, comfortable design
With a naturally shaped grip designed for maximum comfort over hours of use, you'll always be the last gamer standing. DPI shift controls lie in easy reach of the index finger. Six individually sculpted side buttons are easily identifiable by touch – ready just when you need them. And slip-resistant grips around the sides improve control even through hours-long gaming sessions -
Ultra-durable build
Gaming conditions torture typical mice. G602 is designed to endure. Upgraded primary mechanical microswitches are rated to a 20 million-click lifespan. The low-friction polytetrafluoroethylene feet are tested to last an amazing 250 km -
Easy-to-use setup software
Use the optional Logitech Gaming Software (LGS) to perfectly match its commands to your favorite games. Simple drag-and-drop settings allow you to customize button and tracking profiles for any game you play. Or, use pre-configured customizations with automatic game detection
- Logitech Gaming Mouse G602 - mouse - 2.4 GHz
- Mouse
- Connectivity Technology
- Wireless - 2.4 GHz
- Orientation
- Right-handed
- Movement Detection Technology
- Laser
- Buttons Qty
- 11
- Movement Resolution
- 2500 dpi
- Performance
- 500 reports per second, 20 G maximum acceleration, realtime sensitivity switching 250 - 2500 dpi, 80 inches per second
- Programmable buttons, scrolling wheel, sensitivity adjustment, battery indicator, Delta Zero sensor technology
- Cables Included
- USB extension cable - external
- Battery
- 2 x AA type
- OS Required
- Apple MacOS X 10.6.8 or later, Microsoft Windows Vista / 7 / 8
- 3-year warranty
- Mouse
- Orientation
- Right-handed
Input Device
- Wireless
- Interface
- 2.4 GHz
- Max Operating Distance
- Up to 3 m
- Laser
- Buttons Qty
- 11
- 2500 dpi
- Performance
- 1 x USB - 4 pin USB Type A
- Cables Included
- AA type
- Installed Qty
- 2
- OS Required
- Limited warranty - 3 years
