Logitech G600 MMO Gaming Mouse - White
Quicklinx: 85T9WS00 Mfr#: 910-002873
Complete control in your favorite MMOs
G600 MMO Gaming Mouse:
20 MMO-tuned buttons
G-Shift function
Crafted for comfort
Make it yours - easily
Want to customize the default settings? Want access to more intricate macro and scripting capabilities than the onboard macros can provide? Download the optional Logitech Gaming Software and tweak your settings to perfection.
Onboard brains
The three memory profiles are stored onboard so you can access all your button, tracking, and lighting color information on any computer with no software required.
Double down with G-Shift
Assigning the G-Shift function to a button on the G600 doubles the functionality of the other buttons on the mouse - giving you massive configuration power and flexibility
Shift DPI on the fly
For precision targeting or sniping, assign a DPI Shift button to quickly change the DPI value. When you let go, you're back to the standard value. Set up to five DPI levels per profile.
Shaped to go the distance
The G600 is sculpted to support your hand through hours of raiding, PVP, or just grinding XP. Every button is tuned to reduce click fatigue without accidental actuations.
Gaming-grade laser tracking
The G600's gaming-grade laser sensor that will track the tiniest nudge or the fastest flick with equal precision.
Put to the test, built to last
The three large primary buttons are each rated to 20 million clicks. Durability testing pounds keys three times per second, 24/7, for nearly three months so you'll never have misclicks.
1 millisecond USB report rate
Input lag won't be a problem. The G600's USB report rate insures that all your click and movement information are reported instantly to the game. A thousand reports per second takes advantage of your PC's maximum communication speed.
Braided USB cable
The flexible, 6-1/2 foot long USB cable is cloth-wrapped for additional durability and a premium look. And it comes with a hook-and-loop cable strap to help you keep things tidy.
Low-friction feet
Ultra low-friction feet significantly reduce the amount of effort required to move the mouse, resulting in less fatigue in long game sessions.
  • 20 MMO-tuned buttons
    Three primary buttons. Twelve thumb buttons. A clickable scroll wheel that tilts. DPI and profile switching. All pre-configured for optimal MMO use right out of the box - no drivers required.
  • Thumb panel in easy reach
    Focus on burning down the boss without ever worrying about misclicks. The G600 thumb panel is meticulously designed for quick and easy no-look navigation. Two distinct sets of six buttons naturally guide your thumb to just the right spot.
  • Light it up your way
    The thumb panel's RBG illumination is fully customizable with over 16 million possible combinations. Set colors to pulse on and off, or configure them to continuously change.
Logitech Gaming Mouse G600 MMO - mouse - USB - white
Mouse
Wired - USB
White
Orientation
Right-handed
7.5 cm x 11.8 cm x 4.1 cm
133 g
Movement Detection Technology
Laser
Buttons Qty
20
Movement Resolution
8200 dpi
Performance
30 G maximum acceleration, 1 ms response time, 1000 reports per second, 160 inches per second, realtime sensitivity switching 200 - 8200 dpi, 11.25 megapixels per second
Profile switch, scrolling wheel, Tilt Wheel technology, customizable light system, braided cable, G-Shift function
1 x USB cable - integrated - 1.98 m
Microsoft Windows Vista / 7, Windows 8
Microsoft Certification
Compatible with Windows 7
3-year warranty
Mouse
Orientation
Right-handed
7.5 cm
11.8 cm
4.1 cm
133 g
White
Input Device
Wired
USB
Laser
Buttons Qty
20
Movement Resolution
8200 dpi
Performance
1 x USB - 4 pin USB Type A
Limited warranty - 3 years
