With 20 buttons, the Logitech G600 MMO gaming mouse is the most customizable and easy to use mouse specifically designed for mastering your favorite MMOs.
20 MMO-tuned buttons
Pre-configured for optimal MMO use right out of the box. G600 includes three primary buttons, 12 thumb buttons, a clickable scroll wheel that tilts and a G-switch to double down and dominate. Use optional Logitech Gaming Software for full programmability and customization -
Dual-dish thumb panel
Put immediate access to all 12 primary MMO skills under your thumb. The unique dual-dish design of the thumb panel was developed with direct input from both MMO gamers and leading MMO game developers. Field-testing led to two carefully positioned sets of six buttons, helping to reduce both learning time and action timings. And the actuation force is carefully tuned to minimize misclicks -
G-shift button
Use the G-Shift button to double the total number of customizable functions. In its default setting, holding the G-shift button down activates a second function to each G-key. Or set G-Shift to temporary change DPI for extra cursor precision -
Custom-color backlighting
Locate keys in any room with custom backlit keys. Choose 1 out of 16 million colors and assign a unique color to each profile, profile mode, and mode style in the same game. You can tell, without looking down, which mode you're in to ensure your setup is optimized -
Custom-color lighting
Customize the thumb panel lighting for a clear visual reference of up to 3 active profiles and 3 different sub modes. Choose 1 out of 16 million colors and assign a unique color to each profile, profile mode and mode style in the same game. Make colors pulse on-and-off or cycle continuously -
Onboard memory profiles
Program up to three profiles for individual players or games (keyboard macros and DPI settings), and bring your game to other PCs with no software required -
On-the-fly dpi switching
Quickly shift DPI levels, from pixel-precise targeting (200 DPI) to lightning-fast maneuvers (up to 8200 DPI), all with a single button press located behind the scroll wheel, or by reassigning the ring-finger button for temporary shifts in cursor speed while held down -
Durable build
Gaming conditions torture typical mice. All three primary buttons are rated to a 20 million-click lifespan. Low-friction polytetrafluoroethylene feet are tested to last an amazing 250 km. G600 is designed to endure -
Naturally contoured grip
With a natural contoured grip designed for maximum comfort and every button carefully positioned to reduce click fatigue while avoiding accidental actuations, you'll always be the last gamer standing -
Gaming-grade laser
When the difference between MVP and also-ran is measured in pixels, laser sharp sensitivity pays off. G600 uses a gaming-grade laser that delivers precision at any hand speed and works across a wide range of surfaces to register even the most subtle hand movements -
Braided USB cable
With a cloth wrapped, durable 2 m (6.5 ft) USB cord, your G600 mouse comes with a hook-and-loop cable to keep things tidy and ready to play -
1-millisecond report rate
Be confident your every command is executed as fast as possible. The 1000 Hz report rate is up to eight times faster than a standard USB mouse. G600 captures your moves as fast as you can make them -
Low-friction feet
The low-friction polytetrafluoroethylene feet eliminate friction on nearly any surface for smoother motions, precise cursor movements and improved accuracy -
Easy-to-use setup software
Use the optional Logitech Gaming Software to perfectly match its commands to your favorite games. Simple drag-and-drop settings allow you to customize button and tracking profiles for any game you play. Or, use pre-configured customizations with automatic game detection. Learn more about Logitech Gaming Software
- Logitech Gaming Mouse G600 MMO - mouse - USB - black
- Mouse
- Connectivity Technology
- Wired - USB
- Black
- Orientation
- Right-handed
- 7.5 cm x 11.8 cm x 4.1 cm
- 133 g
- Movement Detection Technology
- Laser
- Buttons Qty
- 20
- Movement Resolution
- 8200 dpi
- Performance
- 30 G maximum acceleration, 1 ms response time, 1000 reports per second, 160 inches per second, realtime sensitivity switching 200 - 8200 dpi, 11.25 megapixels per second
- Profile switch, scrolling wheel, Tilt Wheel technology, customizable light system, braided cable, G-Shift function, 5 DPI levels
- Cables Included
- 1 x USB cable - integrated - 2 m
- OS Required
- Microsoft Windows Vista / 7 / 8
- Microsoft Certification
- Compatible with Windows 7
- Mouse
- Orientation
- Right-handed
- 7.5 cm
- 11.8 cm
- 4.1 cm
- 133 g
- Black
Input Device
- Wired
- Interface
- USB
- Laser
- Buttons Qty
- 20
- 8200 dpi
- Performance
- 1 x USB - 4 pin USB Type A
- Cables Included
- OS Required
