Proteus Core allows you to change the weight, balance, and enables you to adapt to wherever you choose to play. Customize it to the way you game and make it yours! Fine tune Proteus Core to your playing surface for better accuracy, precision and responsiveness. A quick tuning process, and you are battle ready.
Personally-tuned Performance
Fine tune the optical sensor in Proteus Core to your playing surface for better accuracy, precision and responsiveness. A quick tuning process, and you are battle ready. G502 Proteus Core is pre-tuned for Logitech gaming mouse pads, G240 and G440. Add a mouse pad for extreme accuracy -
You control the weight and balance
Customize the gaming mouse to the weight and balance that feels good to you. Proteus Core comes with five 3.6g weights. Add some or all, and arrange their positions for a mouse tailored to you -
11 programmable buttons
You have go-to game commands and macros. Program each of the 11 buttons with your favorites. Save your setting to one of the onboard profiles. Or, select from thousands of profiles on your PC -
In-game DPI shifting
Proteus Core helps you be an unstoppable force in low or high DPI. Shift through five DPI settings, from headshot-precise 200 DPI targeting to lightning-fast 12,000 DPI maneuvers -
Gaming-grade dual-mode, hyper-fast scroll wheel
You decide the mode with Proteus Core. Choose whether you want click-to-click precision or hyper-fast scrolling -
Additional Features
Most accurate sensor on the market 32-bit microcontroller 3 on-board profiles 1 millisecond report rate Primary buttons rated to 20 million clicks Mechanical microswitches Improved keyplate design for better click feeling and performance Braided cable with hook and loop cable tie Sleep mode disabled 3 DPI indicator LEDs Rubber grips Magnetic weight-cavity door
- Logitech Proteus Core G502 - mouse - USB
- Mouse
- Connectivity Technology
- Wired - USB
- 7.5 cm x 13.2 cm x 4 cm
- 168 g
- Movement Detection Technology
- Optical
- Buttons Qty
- 11
- Movement Resolution
- 12000 dpi
- Performance
- Realtime sensitivity switching 200 - 12000 dpi, 300+ inches per second, 40 G maximum acceleration
- Programmable buttons, scrolling wheel, sensitivity adjustment, battery indicator
- OS Required
- Microsoft Windows 7, Microsoft Windows Vista, Windows 8, Windows 8.1
- 3-year warranty
- Mouse
- 7.5 cm
- 13.2 cm
- 4 cm
- 168 g
Input Device
- Wired
- Interface
- USB
- Optical
- Buttons Qty
- 11
- 12000 dpi
- Performance
- 1 x USB - 4 pin USB Type A
- OS Required
- Limited warranty - 3 years
