Play games, play music, and play with friends. G435 Gaming Headset connects to your PC, phone and other devices through gaming-grade LIGHTSPEED wireless and Bluetooth . It delivers powerful and clean sound while beamforming mics reduce background noise. It's also made with a minimum 22% post-consumer recycled plastic. Play never ends with G435.
LIGHTSPEED WIRELESS
LIGHTSPEED is gaming-grade wireless that lets you play with high-performance audio response, strong connectivity, and long battery life. All with up to 10 meters / 33 feet in range. You can use LIGHTSPEED on PC, Mac, PlayStation 4 and PlayStation 5 -
BLUETOOTH WIRELESS
When you want to connect G435 to another device, you can still play at high-speeds with low-latency Bluetooth . And of course, you can also listen to music and talk to friends. If you're the proud owner of a G435 headset, you might be due for an update that will allow Bluetooth pairing with your Nintendo Switch. Click here to update your firmware -
18 HOURS OF PLAY TIME
Whether you're gaming or listening to music, you'll be able to enjoy your wireless experience for 18 hours on a full charge -
LIGHTWEIGHT COMFORT
Weighing in at only 165 grams, G435 is lightweight and comfortable enough to wear all day -
DOWN TO SIZE
G435 fits a wide range of players but is optimized for the comfort of younger players and those with smaller heads
- Logitech Lightspeed G435 - headset
- Product Type
- Headset - Bluetooth / 2.4 GHz radio frequency - wireless
- Recommended Use
- Game console, computer
- White
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wireless
- Wireless Technology
- Sound Effects
- Windows Sonic surround sound
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 83.1 dB/mW
- Impedance
- 45 ohm
- Microphone Operation Mode
- Beamforming
- Software Certification
- Discord Certified
- Product Type
- 16.3 cm
- 7.1 cm
- 17 cm
- 165 g
- White
- Recommended Use
- Max Operating Distance
- 10 m
Audio Output
- Full size
- Wireless
- Built-in Decoders
- Dolby Atmos
- Sound Effects
- 20 - 20000 Hz
- Sensitivity
- 83.1 dB/mW
- Impedance
- 45 ohm
- LIGHTSPEED wireless technology
Microphone
- Form Factor
- Built-in
- Beamforming
- 100 - 8000 Hz
- Connector Type
- USB (24 pin USB-C)
- Included Accessories
- USB receiver
- Cable Details
- USB-C charge cable
- Discord Certified
- CarbonNeutral
- Battery
- Headset battery rechargeable
- Run Time (Up To)
- 18 hour(s)
