Logitech G435 Wireless Gaming Headset - Black
Quicklinx: H93DWS00 Mfr#: 981-001050
Type: Headset
16 In Stock
£62.49 ex VAT
£74.98 inc VAT
Play games, play music, and play with friends. G435 Gaming Headset connects to your PC, phone and other devices through gaming-grade LIGHTSPEED wireless and Bluetooth . It delivers powerful and clean sound while beamforming mics reduce background noise. It's also made with a minimum 22% post-consumer recycled plastic. Play never ends with G435.
  • LIGHTSPEED WIRELESS
    LIGHTSPEED is gaming-grade wireless that lets you play with high-performance audio response, strong connectivity, and long battery life. All with up to 10 meters / 33 feet in range. You can use LIGHTSPEED on PC, Mac, PlayStation 4 and PlayStation 5
  • BLUETOOTH WIRELESS
    When you want to connect G435 to another device, you can still play at high-speeds with low-latency Bluetooth . And of course, you can also listen to music and talk to friends. If you're the proud owner of a G435 headset, you might be due for an update that will allow Bluetooth pairing with your Nintendo Switch. Click here to update your firmware
  • 18 HOURS OF PLAY TIME
    Whether you're gaming or listening to music, you'll be able to enjoy your wireless experience for 18 hours on a full charge
  • LIGHTWEIGHT COMFORT
    Weighing in at only 165 grams, G435 is lightweight and comfortable enough to wear all day
  • DOWN TO SIZE
    G435 fits a wide range of players but is optimized for the comfort of younger players and those with smaller heads
Logitech Lightspeed G435 - headset
Headset - Bluetooth / 2.4 GHz radio frequency - wireless
Recommended Use
Game console, computer
Headphones Form Factor
Full size
Wireless
Wireless Technology
Sound Effects
Windows Sonic surround sound
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 83.1 dB/mW
Impedance
45 Ohm
Microphone Operation Mode
Beamforming
Software Certification
Discord Certified
16.3 cm
7.1 cm
17 cm
165 g
Recommended Use
Max Operating Distance
10 m
Audio Output
Full size
Wireless
Wireless Technology
Built-in Decoders
Dolby Atmos
Sound Effects
Frequency Response
20 - 20000 Hz
Sensitivity
83.1 dB/mW
Impedance
45 Ohm
LIGHTSPEED wireless technology
Microphone
Built-in
Beamforming
Frequency Response
100 - 8000 Hz
Connector Type
USB (24 pin USB-C)
USB receiver
Cable Details
USB-C charge cable
Discord Certified
CarbonNeutral
Headset battery rechargeable
Run Time (Up To)
18 hour(s)
Type: Headset
Brand: Logitech
