The G430 earpieces have been designed to be slimmer and lighter, without skimping on audio quality. A lighter, balanced assembly means you stay focused on the game. You might even forget you're wearing a headset. You can hear up to seven discrete channels of audio data plus the low-frequency effects (LFE) channel, known as 7.1 surround sound. Dolby Headphone technology perceptually positions each channel in the correct location to reproduce multi-channel content the way developers intended.
ON-CABLE CONTROLS
Adjust the volume or mute in seconds. Audio controls are located on the 2.3-meter cable, so they are always within reach -
SURROUND SOUNDS AUDIO
Hear the game the way the developer intended. G430 now comes with both Dolby and DTS Headphone:X surround sound modes. Experience audio with lifelike special awareness as you have never before -
ROTATING EAR CUPS
The ear cup pivots for a personalized fit, and rotates 90 degrees to lay flat. The lay-flat design makes them easier to transport and more comfortable when resting around the neck -
SPORTS-PERFORMANCE EAR PADS
G430 ear pads are covered with sports-performance cloth for a soft-touch comfort, even after hours of use. Slip off the cloth cover to wash, and keep the headset in top shape -
LIGHTWEIGHT DESIGN
Stay focused on the game, not your headset. G430 ear cups are designed to be slimmer and lighter, without skimping on audio quality. You might forget you're wearing them -
NOISE-CANCELLING MIC
Be heard loud and clear without the distraction of background noise. Adjust the mic to pick up only your voice -
ON-CABLE CONTROLS
ROTATING EAR CUPS
LIGHTWEIGHT DESIGN
ON-CABLE CONTROLS
- Logitech G430 - headset
- Product Type
- Headset - 7.1 channel - wired
- Recommended Use
- Computer
- Headphones Form Factor
- Full size binaural
- Foldable
- Connectivity Technology
- Wired
- Headphones Technology
- Dynamic
- Sound Output Mode
- Surround Sound
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 90 dB
- Impedance
- 32 Ohm
- Microphone
- Boom
- Microphone Technology
- Electret condenser
- Microphone Operation Mode
- Mono
- Controls
- Volume
- 3-year warranty
- Product Type
- 18.4 cm
- 8.92 cm
- 18.9 cm
- 255 g
- Recommended Use
- Computer
Audio Output
- Foldable
- Dynamic
- Wired
- Sound Output Mode
- Surround Sound
- 20 - 20000 Hz
- Sensitivity
- 90 dB
- Impedance
- 32 Ohm
- Diaphragm
- 40 mm
- In-Cord Volume Control
Microphone
- Boom
- Mono
- Sensitivity
- -40 dBV/Pascal
- Impedance
- 2.2 kOhm
- 50 - 20000 Hz
- Audio Input Details
- Cardioid (uni-directional)
Remote Control
- Controls
- Volume
- Connector Type
- Headphones (mini-phone stereo 3.5 mm) , Microphone (mini-phone 3.5mm) , USB (4 PIN USB Type A)
- Included Accessories
- USB adapter
- Cable Details
- Headset cable - 2.33 m
- Limited warranty - 3 years
