Logitech G413 SE Mechanical Gaming Keyboard
Quicklinx: H936WS00 Mfr#: 920-010555
Type: Keyboard
17 In Stock
£66.66 ex VAT
£79.99 inc VAT
Meet G413 SE-a full-size keyboard for those who need performance in play. With tactile mechanical switches, 6-key rollover anti-ghosting and wear-resistant PBT keycaps, it has the gaming-grade features and reliable durability required to compete.
  • TACTILE MECHANICAL SWITCHES
    G413 SE comes with full-size layout for peak performance. Gaming-grade tactile mechanical switches deliver subtle feedback through the actuation moment-ideal for split-second decisions in competitive and FPS gaming
  • LED LIGHTING
    Whether you're in a competitive match or playing with friends, focus is a must. G413 SE features white LED lighting thoughtfully designed to enhance concentration and clarity
  • 6-KEY ROLLOVER WITH ANTI-GHOST
    6-key rollover with an anti-ghosting gaming matrix provides total control in the heat of the game. Press multiple keys seamlessly and simultaneously
  • BUILT TO LAST
    G413 SE features a black brushed aircraft-quality 5052 low-carbon aluminum alloy top case, gaming-grade mechanical switches and PBT keycaps for a premium experience and superior durability
Logitech G G413 SE - keyboard - QWERTY - UK - black Input Device
Keyboard
Backlit
White
USB
Wired
Localization and Layout
QWERTY UK
Hot Keys Function
Multimedia
Numeric Keypad
Gaming
Key Switch Type
Tactile
43.5 cm x 12.7 cm x 3.63 cm
780 g
Keyboard
Backlit
White
USB
Hot Keys Function
Multimedia
QWERTY UK
Keyboard Technology
Mechanical
Key Switch Type
Tactile
Anti-ghosting
Simultaneous Key Press Quantity
6
Gaming
Numeric keypad
43.5 cm
12.7 cm
3.63 cm
780 g
Cable Length
1.8 m
Windows 10 or later, Apple macOS 10.14 or later
Type: Keyboard
Brand: Logitech
