Meet G413 SE-a full-size keyboard for those who need performance in play. With tactile mechanical switches, 6-key rollover anti-ghosting and wear-resistant PBT keycaps, it has the gaming-grade features and reliable durability required to compete.
TACTILE MECHANICAL SWITCHES
G413 SE comes with full-size layout for peak performance. Gaming-grade tactile mechanical switches deliver subtle feedback through the actuation moment-ideal for split-second decisions in competitive and FPS gaming -
LED LIGHTING
Whether you're in a competitive match or playing with friends, focus is a must. G413 SE features white LED lighting thoughtfully designed to enhance concentration and clarity -
6-KEY ROLLOVER WITH ANTI-GHOST
6-key rollover with an anti-ghosting gaming matrix provides total control in the heat of the game. Press multiple keys seamlessly and simultaneously -
BUILT TO LAST
G413 SE features a black brushed aircraft-quality 5052 low-carbon aluminum alloy top case, gaming-grade mechanical switches and PBT keycaps for a premium experience and superior durability
- Logitech G G413 SE - keyboard - QWERTY - UK - black Input Device
- Keyboard
- Backlit
- White
- Interface
- USB
- Connectivity Technology
- Wired
- Localization and Layout
- QWERTY UK
- Hot Keys Function
- Multimedia
- Numeric Keypad
- Gaming
- Key Switch Type
- Tactile
- Black
- 43.5 cm x 12.7 cm x 3.63 cm
- 780 g
- 2-year warranty
- Keyboard
- Backlit
- White
- Interface
- USB
- Hot Keys Function
- Multimedia
- QWERTY UK
- Keyboard Technology
- Mechanical
- Key Switch Type
- Tactile
- Anti-ghosting
- Simultaneous Key Press Quantity
- 6
- Gaming
- Numeric keypad
- 43.5 cm
- 12.7 cm
- 3.63 cm
- 780 g
- Black
- Cable Length
- 1.8 m
- OS Required
- Windows 10 or later, Apple macOS 10.14 or later
- Limited warranty - 2 years
