G413 was thoughtfully conceived, designed and engineered to deliver advanced performance with just the right feature set. Lightweight, high-strength 5052 aluminum alloy top case enables the slim, bladelike chassis. Underneath find mouse and headset cable management, plus adjustable-height feet with rubber stabilizers, for confidence during intense gameplay.
The Romer-G mechanical switch is purpose-built for pro-grade performance, responsiveness and durability. The short-throw actuation at 1.5mm offers a perfect blend of speed, precision and quiet performance, Romer-G is the stealth assassin of mechanical gaming keyboard switches.
Pure. Power. Play
G413 was thoughtfully conceived, designed and engineered to deliver advanced performance with just the right feature set. Lightweight, high-strength 5052 aluminum alloy top case enables the slim, bladelike chassis. Underneath find mouse and headset cable management, plus adjustable-height feet with rubber stabilizers, for confidence during intense gameplay -
Advanced Mechanical
The Romer-G mechanical switch is purpose-built for pro-grade performance, responsiveness and durability. The short-throw actuation at 1.5mm is 25% faster than the competition's standard mechanical switches. A perfect blend of speed, precision and quiet performance, Romer-G is the stealth assassin of mechanical gaming keyboard switches. Get the Romer-G story -
Precision Key Lighting
Romer-G is also purpose-designed for precise and clean lighting through the keycap. So, keys are always visible and never distracting, especially during late night gaming sessions (the best kind). That's how G413 Carbon in elemental red backlighting and G413 Silver in iconic white achieve their premium, focused look -
Aircraft-grade Aluminum Alloy
The brushed 5052 aluminum-magnesium alloy top case serves as the keyboard's backbone. The result is a minimal design balanced with a full set of features. With a focus on high-end finish and performance, G413 is crafted from the highest-grade materials -
USB Passthrough
Convenience and speed are directly within reach. The additional, dedicated USB cable connects the USB passthrough port to its own input for 100% power throughput and data speed. Plug in a device to charge or plug in a mouse to charge your adversaries, without missing a beat -
Full Function Keys
Use the FN key to control volume, play and pause, mute, game mode, lighting, etc. Use the FN toggle feature in Logitech Gaming Software (LGS) and configure keys to perform media commands by default. Even with a clean and simple design, G413 is packed with the premium features gamers want. Download LGS Now -
Gaming Keycaps
12 additional keycaps come with G413, so you can upgrade critical gaming keys to be as heroic as your gameplay. Swap them fast and easy with the included puller to remove your Romer-G keycaps -
Advanced Features
Don't lose a game because you fat-fingered the Windows key. Toggle game mode with FN+F8. Deactivate additional keys using LGS. Press multiple keys plus modifier keys (Control, Alt, Shift) simultaneously in any order and get what you intended with 26-key rollover. Performance-tuned anti-ghosting gives you reliable control when multiple gaming commands are given simultaneously -
Programmable Macros
Use Logitech Gaming Software to program custom functions and macro commands on F1-F12 buttons. Make your gamer life easier. Execute complex commands, or unleash a timed series of actions or spells with the press of a button. Download LGS Now
- Logitech G413 - keyboard - QWERTY - UK - carbon Input Device
- Keyboard
- Backlit
- Red
- Interface
- USB
- Connectivity Technology
- Wired
- Localization and Layout
- QWERTY UK
- Hot Keys Function
- Multimedia, programmable, backlight control, gaming mode key
- Numeric Keypad
- Gaming
- Key Switch Type
- Romer-G
- Carbon
- 44.5 cm x 13.2 cm x 3.4 cm
- 1.105 kg
- 2-year warranty
- Keyboard
- Backlit
- Red
- Interface
- USB
- Hot Keys Function
- QWERTY UK
- Keyboard Technology
- Mechanical
- Key Switch Type
- Romer-G
- Gaming
- Adjustable Height
- Detachable Cable
- Numeric keypad
- 44.5 cm
- 13.2 cm
- 3.4 cm
- 1.105 kg
- USB 2.0
- Carbon
- Cable Length
- 1.8 m
- Included Accessories
- Keycap puller, 12 keycaps
- OS Required
- Microsoft Windows 7 / 8 / 8.1 / 10
- Limited warranty - 2 years
