With rubber grips on the left and right sides to give you added control, the G403 Prodigy was made to mold to your hand for long-lasting comfort during gameplay. In a lightweight, ergonomically designed body, G403 brings together supreme comfort, quality, and durability.
With G403 Prodigy, the game gets better and so do you. Prodigy is built for gaming speed, accuracy and endurance. With a 1ms report rate, G403 is up to 8x faster than standard mice - which means when the mouse is moved or clicked, the response is near-instantaneous.
Become more accurate than you've ever been before. The G403 Prodigy features the world's most advanced gaming mouse sensor, used by eSports pros worldwide. Exceptionally precise and consistent, it gives you the confidence of quicker responses and more accurate targeting.
Lag-Free Wireless
G403 is equipped with the same wireless technology pioneered by Logitech in the award-winning G900 Chaos Spectrum. G403 Wireless has an incredibly optimized 2.4GHz wireless connection has a lightning-fast 1ms report rate for incredible lag-free responsiveness that outperforms the competition's mice, even wired ones -
Gaming-Grade Performance
With G403, the game gets better and so do you. Is built for gaming speed, accuracy and endurance. With a 1ms report rate whether wired or wireless, G403 is up to 8x faster than standard mice - which means when the mouse is moved or clicked, the response is near-instantaneous -
Elevate Your Accuracy
Become more accurate than you've ever been before. The G403 features the world's most advanced gaming mouse sensor, used by eSports pros worldwide. Exceptionally precise and consistent, it gives you the confidence of quicker responses and more accurate targeting -
Ergonomically designed
G403 brings together supreme comfort, quality, and durability in a lightweight, ergonomically designed body. With rubber grips on the left and right sides to give you added control, the G403 Wireless was made to mold to your hand for long-lasting comfort during gameplay -
Adjustable Weight System
The included 10g removable weight gives you options when it comes to tuning the mouse exactly to your preferences. With the weight removed, the mouse weighs in at a lightweight 107g -
Programmable RGB Lighting
Logitech G403 Gaming Mouse can be used directly out-of-the-box, or can be fully configured using Logitech Gaming Software to match exactly to your preferences. Choose from a palette of approximately 16.8 million colors and brightness levels to match your favorite team, personal style, system or environment -
Advanced button tensioning
Advanced button tensioning uses metal springs to help keep the left and right mouse buttons primed to click, reducing the force needed to click and delivering exceptional click feel, response, and consistency -
Onboard memory
With onboard memory, you can take your settings with you wherever you go. Save your settings to the memory on the mouse and use your settings on any PC without needing additional software or requiring a log in to use them -
Six programmable buttons
Logitech G403 Wireless Gaming Mouse can be used with preset programming or fully configured to match your preferences. Advanced users can configure the 6 programmable buttons to sequences of clicks and keystrokes to simplify in-game actions and quickly execute complex tasks -
Programmable DPI settings
On-the-fly DPI shifting that lets you program and switch between up to 5 sensitivity settings, from pixel-precise targeting (200 DPI) for sniping, to lightning-fast maneuvers (up to 12000 DPI) for fast 180-degree turns
- Logitech Gaming Mouse G403 Prodigy - mouse - 2.4 GHz, USB
- Mouse
- Connectivity Technology
- Wireless, wired - 2.4 GHz, USB
- 6.8 cm x 12.4 cm x 4.3 cm
- 107.2 g
- Wireless Receiver
- USB wireless receiver
- Buttons Qty
- 6
- Movement Resolution
- 12000 dpi
- Performance
- Realtime sensitivity switching 200 - 12000 dpi, 1000 reports per second, 300 inches per second, 40 G maximum acceleration, 1 ms response time
- Adjustable weight, 16.8 million multi-colour illumination, 6 programmable buttons, built-in flash memory
- Cable Length
- 1.83 m
- OS Required
- Microsoft Windows 7 / 8 / 8.1 / 10
- 2-year warranty
- Mouse
- Wireless Receiver
- 6.8 cm
- 12.4 cm
- 4.3 cm
- 107.2 g
Input Device
- Wireless, wired
- Interface
- 2.4 GHz, USB
- Buttons Qty
- 6
- 12000 dpi
- Performance
- Cable Length
- 1.83 m
- Included Accessories
- Weight system
- OS Required
- Limited warranty - 2 years
