Logitech G402 Hyperion Fury FPS Gaming Mouse
Quicklinx: BGWYWS00 Mfr#: 910-004068
The world's fastest gaming mouse. Whether you're lining up a headshot or dodging heavy fire, Hyperion Fury offers the blazing-fast tracking and pinpoint accuracy you need.
  • Fusion Engine high-speed tracking
    Hyperion Fury combines an optical sensor featuring Logitech Delta Zero technology with our exclusive Fusion Engine hybrid sensor to enable tracking speeds in excess of 500 IPS
  • 8 programmable buttons
    Customize your mouse with 8 programmable buttons. Whether you want to toss a grenade or quickly access your inventory, it's at your fingertips. Optional Logitech Gaming Software makes set up easy
  • On-the-fly DPI switching
    Switch through four DPI settings in an instant. Snipe a foe across the map (250 DPI) before fleeing in the blink of an eye (4000 DPI). With on-the-fly DPI switching, you have the flexibility to react to the chaos of battle with precision
  • 32-bit ARM processor
    Hyperion Fury on-board ARM processor powers the Fusion Engine for incredible tracking speeds while allowing you to save and play back your favorite macros. With Logitech Gaming Software, craft and assign macros that can be accessed from Hyperion Fury with ease
  • 1ms Report rate
    With a 1 millisecond report rate, you can be confident that your movement will be communicated via USB at fast speeds without troublesome lag
  • Comfortable design
    An update to the classic G400s shape to enhance function and comfort. A combination of lightweight materials and rubber grips will help to ensure that your gaming sessions last as long as possible
  • High-speed clicking
    Distinct left and right buttons offer extreme responsiveness. With high-speed clicking, you can push your skills even further while enjoying the edge in intense firefights. Faster, more comfortable clicking makes all the difference with Hyperion Fury
Logitech Hyperion Fury G402 - mouse - USB
Mouse
Wired - USB
Orientation
Right-handed
7.2 cm x 13.6 cm x 4.1 cm
144 g
Buttons Qty
8
Movement Resolution
4000 dpi
Performance
1 ms response time, 16 G maximum acceleration, 500+ inches per second, realtime sensitivity switching 240 - 4000 dpi
Fusion Engine, programmable buttons, on-the-fly DPI switching with 4 stage LED light indicator, rubber side grips, ARM 32-bit processor
Microsoft Windows Vista / 7 / 8 / 8.1
Mouse
Orientation
Right-handed
7.2 cm
13.6 cm
4.1 cm
144 g
Input Device
Wired
USB
Buttons Qty
8
Movement Resolution
4000 dpi
Performance
1 x USB - 4 pin USB Type A
