Lightweight and cool. G335 is where color and comfort combine. Featuring a suspension headband design with adjustable strap so you can choose your most comfortable fit. Easy plug-and-play and built-in controls let you quickly connect and jump into the game. Just pick your favorite color to match your awesome style.
PLAY YOUR WAY
Lightweight and cool. G335 is where color and comfort combine. Featuring a suspension headband design with adjustable strap so you can choose your most comfortable fit. Easy plug-and-play and built-in controls let you quickly connect and jump into the game. Just pick your favorite color to match your awesome style -
GET INTO THE COMFORT ZONE
The suspension headband design distributes weight and relieves pressure points. Soft, breathable memory ear cups and sports mesh material surround the ear and provide just the right amount of force to stay firmly in place. At only 240 grams, G335 is a smaller and lighter version of the award-winning G733 LIGHTSPEED wireless headset -
PLUG AND PLAY
Easily get into the game using a simple 3.5 mm audio jack. G335 works with Xbox , PlayStation , Nintendo Switch as well as most PCs, laptops, or mobile devices -
ADJUST TO FIT
The soft elastic headband conforms to your head and can be adjusted for the perfect fit. Slide the ear cups up and down to make them feel just right -
BUILT-IN CONTROLS
Use the volume roller on the ear cup to turn up your game or music. Flip up the mic to instantly mute and move it out of the way -
PLAY IN STYLE
G335 comes in multiple colorways, each with its own vibrant reversible headband straps and matching earpads. The soft elastic straps are reversible to give you a choice of colors and washable-so they always look fresh. When you're ready for a new look and mood, just grab a new strap or choose from a variety of cool, vibrant mic covers -
GREAT AUDIO. GUARANTEED
With 40 mm neodymium drivers, G335 delivers crisp, clear sound that makes your game come alive. It's Discord Certified to guarantee crystal clear communication performance with amazing sound and voice clarity -
FIND THE PERFECT FIT
Two amazing headsets in our Color Collection, both with their own unique features. Choose the one that's right for you. 1. G335 weighs just 240 grams, has slimmer ear pads and is wired for an easy plug-and-play experience. 2. At 278 grams, G733 features LIGHTSPEED wireless, LIGHTSYNC RGB lighting and dual-layer memory foam -
PLAY YOUR WAY
Choose from a variety of colorful gear to suit your playstyle
- Logitech G G335 Wired Gaming Headset - headset - 3.5 mm jack
- Product Type
- Headset - wired - 3.5 mm jack
- Recommended Use
- Game console, portable electronics, computer
- Gaming
- Style
- Games
- White
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 87.5 dB
- Impedance
- 39 Ohm
- Microphone
- Boom
- Microphone Operation Mode
- Cardioid (uni-directional)
- Controls
- Volume, flip-to-mute
- Software Certification
- Discord Certified
- 2-year warranty
- Product Type
- Style
- Games
- 240 g
- White
- Earpad Material
- Memory foam
- Recommended Use
- Gaming
Audio Output
- Full size
- Wired
- Sound Output Mode
- Stereo
- 20 - 20000 Hz
- Sensitivity
- 87.5 dB
- Impedance
- 39 Ohm
- Diaphragm
- 40 mm
- Magnet Material
- Neodymium
- Adjustable Headband
Microphone
- Boom
- Form Factor
- Headset microphone
- 100 - 10000 Hz
Remote Control
- Controls
- Connector Type
- Headset (mini-phone stereo 3.5 mm 4-pole)
- Included Accessories
- Audio splitter
- Cable Details
- Headset cable , Audio splitter - detachable
- Discord Certified
- Plug and Play
- Limited warranty - 2 years
- Shipping Width
- 9.09 cm
- Shipping Depth
- 23.1 cm
- Shipping Height
- 20.9 cm
- Shipping Weight
- 517 g
