Logitech G335 Wired Gaming Headset - White
Quicklinx: H93CWS00 Mfr#: 981-001018
Type: Headset
£54.16 ex VAT
£64.99 inc VAT
Lightweight and cool. G335 is where color and comfort combine. Featuring a suspension headband design with adjustable strap so you can choose your most comfortable fit. Easy plug-and-play and built-in controls let you quickly connect and jump into the game. Just pick your favorite color to match your awesome style.
  • PLAY YOUR WAY
  • GET INTO THE COMFORT ZONE
    The suspension headband design distributes weight and relieves pressure points. Soft, breathable memory ear cups and sports mesh material surround the ear and provide just the right amount of force to stay firmly in place. At only 240 grams, G335 is a smaller and lighter version of the award-winning G733 LIGHTSPEED wireless headset
  • PLUG AND PLAY
    Easily get into the game using a simple 3.5 mm audio jack. G335 works with Xbox , PlayStation , Nintendo Switch as well as most PCs, laptops, or mobile devices
  • ADJUST TO FIT
    The soft elastic headband conforms to your head and can be adjusted for the perfect fit. Slide the ear cups up and down to make them feel just right
  • BUILT-IN CONTROLS
    Use the volume roller on the ear cup to turn up your game or music. Flip up the mic to instantly mute and move it out of the way
  • PLAY IN STYLE
    G335 comes in multiple colorways, each with its own vibrant reversible headband straps and matching earpads. The soft elastic straps are reversible to give you a choice of colors and washable-so they always look fresh. When you're ready for a new look and mood, just grab a new strap or choose from a variety of cool, vibrant mic covers
  • GREAT AUDIO. GUARANTEED
    With 40 mm neodymium drivers, G335 delivers crisp, clear sound that makes your game come alive. It's Discord Certified to guarantee crystal clear communication performance with amazing sound and voice clarity
  • FIND THE PERFECT FIT
    Two amazing headsets in our Color Collection, both with their own unique features. Choose the one that's right for you. 1. G335 weighs just 240 grams, has slimmer ear pads and is wired for an easy plug-and-play experience. 2. At 278 grams, G733 features LIGHTSPEED wireless, LIGHTSYNC RGB lighting and dual-layer memory foam
  • PLAY YOUR WAY
    Choose from a variety of colorful gear to suit your playstyle
Logitech G G335 Wired Gaming Headset - headset - 3.5 mm jack
Headset - wired - 3.5 mm jack
Recommended Use
Game console, portable electronics, computer
Gaming
Style
Games
White
Headphones Form Factor
Full size
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 87.5 dB
Impedance
39 Ohm
Microphone
Boom
Microphone Operation Mode
Cardioid (uni-directional)
Controls
Volume, flip-to-mute
Software Certification
Discord Certified
Style
Games
240 g
White
Earpad Material
Memory foam
Recommended Use
Gaming
Audio Output
Full size
Wired
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
Sensitivity
87.5 dB
Impedance
39 Ohm
Diaphragm
40 mm
Magnet Material
Neodymium
Adjustable Headband
Microphone
Boom
Headset microphone
Frequency Response
100 - 10000 Hz
Remote Control
Controls
Connector Type
Headset (mini-phone stereo 3.5 mm 4-pole)
Audio splitter
Cable Details
Headset cable , Audio splitter - detachable
Discord Certified
Plug and Play
Shipping Width
9.09 cm
Shipping Depth
23.1 cm
Shipping Height
20.9 cm
Shipping Weight
517 g
Type: Headset
Brand: Logitech
