Logitech G305 Wireless Mouse - Black
Quicklinx: DYDVWS00 Mfr#: 910-005283
Wired / Wireless: Wireless
Colour: Black
£41.81 ex VAT
£50.17 inc VAT
Play advanced without wires or limits. Logitech G305 LIGHTSPEED is a wireless gaming mouse designed for high performance in your favorite PC games. G305 features the Logitech G HERO optical sensor with 200 to 12,000 DPI sensitivity for competition-level accuracy. LIGHTSPEED wireless technology gives you super-fast 1-millisecond performance that's as fast as wired. With incredible power efficiency, G305 stays powered and ready to play for up to 250 hours on a single included AA battery. Play anywhere with an ultra-portable, lightweight gaming mouse that is easy to take with you, and has built-in storage for the included USB wireless receiver. G305 is the LIGHTSPEED wireless mouse for all.
  • LIGHTSPEED Wireless for All
    G305 is a LIGHTSPEED wireless gaming mouse designed for serious performance with latest technology innovations at an affordable price point
  • HERO Sensor
    HERO sensor is the next-gen optical gaming sensor from Logitech G that accomplishes both incredible performance and unprecedented efficiency. Because, in wireless gaming, there can be no compromises. Program DPI from 100 - 12,000 and save up to 5 profiles on the onboard memory. 1 More on HERO Sensor
    LIGHTSPEED is wireless as fast as wired. The meticulously engineered, end-to-end solution from Logitech G gives players the freedom of wireless and the 1 ms performance required for gaming. More on LIGHTSPEED
  • Ultra-Long Life
    HERO Sensor and LIGHTSPEED deliver extreme efficiency to let you game for 250 hours on just one AA. Expect around 9 months of typical use, at peak performance, before needing to change your battery. 2 And don't worry, G305 has an indicator light that reminds you at 15% battery remaining
  • Ultra-Lightweight
    At Logitech G, a wireless gaming mouse doesn't need to be heavy. G305 is very light, coming in at only 99 grams, made possible thanks to the lightweight mechanical design and ultra-efficient battery usage
  • 6 Programmable Buttons
    G305 sports 10 million click switches for the two primary buttons. G305 also has middle click, DPI button and two side buttons that can be programmed to your liking using Logitech Gaming Software. 1 Download LGS Now
  • Advanced button tensioning
    Advanced button tensioning with separated buttons enhances the consistency of the left/right mouse buttons and helps reduce the force needed required to click. This results in crisp, reliable click performance you can depend on in even the most intense gaming sessions
  • Play Anywhere
    The durable, lightweight design with a small footprint and built-in nano receiver storage make G305 a great travel companion
Logitech G305 - mouse - LIGHTSPEED - black
Mouse
Wireless - LIGHTSPEED
6.215 cm x 3.82 cm x 11.66 cm
99 g
Wireless Receiver
Movement Detection Technology
Optical
Buttons Qty
6
Movement Resolution
12000 dpi
Performance
1 ms response time, 40 G maximum acceleration, realtime sensitivity switching 200 - 12000 dpi, 400 ips tracking speed
Scrolling wheel, Nano wireless receiver, 6 programmable buttons, ARM 32-bit processor, wireless receiver slot, HERO sensor
AA type
Google Chrome OS, Microsoft Windows 7 or later, Apple MacOS X 10.11 or later
Mouse
Wireless Receiver
6.215 cm
3.82 cm
11.66 cm
99 g
Input Device
Wireless
LIGHTSPEED
Optical
Buttons Qty
6
Movement Resolution
12000 dpi
Performance
1 x USB - 4 pin USB Type A
1 AA alkaline battery, USB receiver extender cable
Plug and Play
AA type
Run Time (Up To)
250 hour(s)
Colour: Black
Brand: Logitech
Price Range Ex VAT: 0 - 50
