Logitech G240 Cloth Gaming Mouse Pad
Quicklinx: DQX0WS00 Mfr#: 943-000045
The cloth surface of G240 provides ideal surface friction for low DPI gaming, improving mouse control and precise cursor placement. Consistent surface texture can improve sensor performance, especially when used with Logitech G gaming sensors. And the soft rubber base maintains stability without sacrificing comfort.
Whether using an optical or laser mouse, G240 can give gamers access to enhanced sensor accuracy and precision. G240 uses a surface texture comparable to the optimal testing environment for Logitech G mice.
At just 1mm thick, G240 maintains a low profile. The soft fabric improves comfort as the wrist moves back and forth across the mouse pad's edge.
With a flexible cloth construction, G240 rolls up for easy transport and lies flat when you're ready to play. Protect the mouse pad when you take it to LAN events using the hexagonal packaging.
  • A firm, flexible foundation
  • Moderate surface friction
    Gamers using low-DPI settings, benefit from moderate resistance to the mouse feet when starting or stopping a rapid movement. Heat-treated at 200° C, the cloth surface of G240 provides just the right amount of friction for low-DPI maneuvers.
  • Consistent surface texture
    Heavy patterns and designs can interfere with sensor performance. G240 features a clean, consistent surface texture. This gives sensors better imagery for translating mouse movement into cursor movement, an improvement over inconsistent or dirty table and desk surfaces.
  • Matched to Logitech G sensors
  • Stable rubber base
    The rubber base firmly bonded to the cloth helps keep the flexible surface in place and prevent the cloth from bunching up in front of the mouse, interfering with smooth mouse movement.
  • Comfortable cloth construction
  • Roll for transport
Logitech G240 - mouse pad
Mouse pad
Product Material
Cloth
34 cm x 28 cm
90 g
3-year warranty
Mouse pad
Product Material
Cloth
34 cm
28 cm
Thickness
0.1 cm
90 g
Rubber base
Limited warranty - 3 years
