Logitech G203 LIGHTSYNC RGB 6 Button Gaming Mouse - Black
Quicklinx: H932WS00 Mfr#: 910-005796
Type: Mouse
Hurry, only 2 left in stock!
£33.33 ex VAT
£39.99 inc VAT
Make the most of your game time with G203 gaming mouse available in a variety of vibrant colors. With LIGHTSYNC technology, a gaming-grade sensor and a classic 6-button design you'll light up your game and your desk.
  • READY TO PLAY
  • Lightsync RGB Color Wave
    Choose from vibrant animations, game- and media-driven settings, or program your own from approximately 16.8 million colors
  • Easy Customization
    Pick one color, blend three, choose a fun animation preset, or make your own. The choice is yours! You can even sync your mouse with other Logitech G LIGHTSYNC gear so it's a perfect match
  • Dynamic Screen Sampling
    Set your lighting to Screen Sampler to make it synchronise with your screen. Set up your mouse to react to color shifts in games, movies, and more
  • AUDIO VISUALIZER
    Play music, movies, games-any sound, really-and G203 will flash colors to the beat. Customize levels and colors to make the dance party all your own
  • GAMING-GRADE SENSOR
    Get accurate cursor tracking and responsive performance thanks to a gaming-grade sensor. With adjustable sensitivity from 200-8,000 DPI, pick the right level that fits your play preference. Use Logitech G HUB software to program up to 5 presets.Advanced features require Logitech G HUB software. Download free at LogitechG.com/downloads
  • TRIED AND TRUE DESIGN
    The classic six-button design provides both comfort and confidence so you can explore, cast spells, and play just like you want. Use Logitech G HUB software to assign in-game commands, system controls, or key binds to buttons and simplify your gameplay
  • OPTIMIZED BUTTON TENSIONING
  • LOGITECH G HUB GAMING SOFTWARE
    G203 is designed to work seamlessly in any system, but if you're looking to fine-tune controls, free-to-download customization software is easy to use and set up. Logitech G HUB software is a complete customization suite that, lets you personalize lighting, sensitivity, and button commands on your G203 mouse.Advanced features require Logitech G HUB software. Download free at LogitechG.com/downloads
  • Button Assignments
    Assign system commands, shortcut keys,  and keyboard commands to the 6 buttons. You can also create powerful macros, which let you input sequences of commands in a row that execute every time you click the assigned button. Advanced features require Logitech G HUB software. Download free at LogitechG.com/downloads
  • Set your Sensitivity
    G203 sensor is capable of sensitivity up to 8,000 DPI (dots per inch). G203 lets you choose sensitivity settings as easy as sliding a scroll bar. Set up to 5 levels and cycle through them with the press of a button.  It's great for games that have different modes or levels that might require more control, like a sniper scope or a speed clicking level
  • Onboard Memory
    When you take your G203 with you, your custom settings can come along. By saving your preferences to the onboard memory using Logitech G HUB device settings you can use it on other computers with no need to install software or reconfigure your settings. Plug and play your way
  • PLAY WITH COLOR
    Gaming gets a new look as Logitech G combines top-notch gaming tech with vibrant color, fresh style, and awesome vibes. Finish your setup with a high-performance headset and keyboard to match
Logitech Gaming Mouse G203 LIGHTSYNC - mouse - USB - black
Mouse
Wired - USB
6.215 cm x 11.66 cm x 3.82 cm
85 g
Movement Detection Technology
Optical
Buttons Qty
6
Movement Resolution
8000 dpi
Performance
1 ms response time, polling rate: 1000 Hz, realtime sensitivity switching 200 - 8000 dpi
Gaming
6 programmable buttons, ARM 32-bit processor, LIGHTSYNC technology
Google Chrome OS, Microsoft Windows 7 or later, Apple MacOS X 10.10 or later
Mouse
Gaming
6.215 cm
11.66 cm
3.82 cm
85 g
Input Device
Wired
USB
Optical
Buttons Qty
6
Movement Resolution
8000 dpi
Performance
1 x USB - 4 pin USB Type A
Type: Mouse
Brand: Logitech
