Logitech G Pro Gaming Mouse Black
Quicklinx: DQW5WS00 Mfr#: 910-004857
The difference between winning and losing in today's games isn't measured in meters or seconds, but micrometers and milliseconds. That's why Logitech G created the pro gaming mouse. Its lightweight body and optical gaming sensor are engineered for the unprecedented speed and precision aiming needed at the highest level of esport competition.
Consistent, pixel-precise accuracy makes a critical difference in high-stakes competitive gameplay. The PMW3366 delivers a level of precision widely considered to be the best by enthusiasts and professionals alike. With zero smoothing, filtering or acceleration across the entire DPI range (200-12,000DPI), it provides exceptional tracking accuracy and consistent responsiveness at any speed.
  • Play like the pros
    Logitech G partners with many of the world's top eSports athletes to design the PRO line with the goal of creating extreme performance gear that lets professionals play at the peak of their potential. The Logitech G PRO gaming mouse has been updated with the HERO 16K sensor and a low-friction, flexible cable. The Logitech G PRO gaming mouse with HERO 16K sensor is the ultimate in speed, accuracy, and responsiveness.
  • HERO sensor
    The HERO optical sensor offers the highest performing and most efficient gaming. An updated tracking algorithm delivers ultra-precise tracking with no acceleration, smoothing, or filtering over the entire DPI range. The HERO 16K sensor exceeds the performance of the previous generation sensor, capable of exceeding 400 IPS and delivering 16,000 DPI tracking with pixel-precise accuracy.
  • Mechanical switches and Spring Button Tensioning System
    Logitech G worked with Omron to engineer a mechanical switch that meets the exacting standards of the PRO line. The PRO mechanical switch delivers the extreme performance and a 50M click durability that professional eSports athletes demand. However, the switch alone is not enough. To achieve PRO grade performance in the real world, Logitech G combines the PRO switch with exclusive Spring Button Tensioning System (SBTS) to provide a consistent feel and near instantaneous actuation.
  • Programmable Lighting & Buttons
    Logitech G PRO Gaming Mouse can be used out-of-the-box or it can be fully configured by accessing the optional Logitech Gaming Software (LGS). With LIGHTSYNC technology, RGB lighting can be customized up to approximately 16.8 million colors, making it possible to sport your team's color, personalize your setup, or synchronize with other G products. Six programmable buttons are available if you prefer to bind custom commands to the mouse itself. With onboard memory, you can also save your preferences directly to the mouse for use on competition systems without the need to install custom software or reconfigure your settings.
  • Comfortable and durable
    Built on decades of Logitech expertise in engineering, building, and testing mice, PRO is designed for comfort and durability. With 50m click switches, the updated Logitech G PRO gaming mouse is designed to be even more durable. The PRO gaming mouse is optimized to reduce weight for improved comfort, stability, and responsiveness. Every aspect of the design was rigorously tested to make sure it can stand up to even the most intense gaming. The surface of the PRO gaming mouse is treated with a special coating to improve durability and grip, mouse feet are tested to over 250 km of use, and left and right buttons are tested to exceed 50 million clicks - the equivalent of a pro gamer training 10 hours every day for five years.
Logitech G Pro - mouse - USB
Mouse
Wired - USB
6.215 cm x 11.66 cm x 3.82 cm
129.5 g
Movement Detection Technology
Optical
Buttons Qty
6
Movement Resolution
12000 dpi
Performance
Realtime sensitivity switching 200 - 12000 dpi, 40 G maximum acceleration, 300 inches per second
Scrolling wheel, RGB colour LED, 6 programmable buttons, built-in flash memory, Pixart PMW 3366 optical gaming sensor
Microsoft Windows 7 / 8 / 8.1 / 10
Mouse
6.215 cm
11.66 cm
3.82 cm
129.5 g
Input Device
Wired
USB
Optical
Buttons Qty
6
Movement Resolution
12000 dpi
Performance
1 x USB 2.0 - 4 pin USB Type A
