The tournament-proven PRO gaming keyboard-now with advanced GX Clicky mechanical switches.
BUILT FOR PROS
The pros asked, we listened. With a compact design and pro-grade clicky switches, PRO is pro-tested, tournament-assured, and built to win -
GX CLICKY SWITCHES
Advanced GX Clicky mechanical switches are engineered for performance, responsiveness, and durability, with an audible and tactile feedback bump -
COMPACT + ULTRA-PORTABLE
A tenkeyless design and detachable cable means more room for mousing and easier travel to tournaments around the world -
LIGHTSYNC RGB
Highlight important keys, or just show your team pride. Customize lighting and animations with G HUB software, and save static lighting designs to onboard memory for tournament systems -
DETACHABLE CABLE
Detachable Micro USB cables feature a three pronged design for an easy, secure connection and safe transport in your travel bag
- Logitech Pro - keyboard - QWERTY - UK - black Input Device
- Keyboard
- Backlit
- RGB
- Interface
- USB
- Connectivity Technology
- Wired
- Localization and Layout
- QWERTY UK
- Hot Keys Function
- Programmable
- Key Switch Type
- GX Blue Clicky
- Black
- 36.1 cm x 15.3 cm x 3.4 cm
- 2-year warranty
- Keyboard
- Backlit
- RGB
- Interface
- USB
- Hot Keys Function
- Programmable
- QWERTY UK
- Keyboard Technology
- Mechanical
- Key Switch Type
- GX Blue Clicky
- Adjustable Height
- Detachable Cable
- 36.1 cm
- 15.3 cm
- 3.4 cm
- Black
- Cable Length
- 1.8 m
- OS Required
- Microsoft Windows 7 or later, Apple MacOS 10.11 or later
- Limited warranty - 2 years
