With POWERPLAY and LIGHTSPEED technology, Logitech G has solved the barriers to high performance wireless gaming. Input lag, wireless disconnects, and dead batteries are now a thing of the past. Welcome to the future of wireless PC gaming, achieved through advanced science and unrivaled engineering. Through innovative application of electromagnetic resonance, the POWERPLAY base creates an energy field above its surface. This allows charging while in motion and delivers wireless power without interfering with the precise measurement and data transmission of a high-performance gaming mouse. Logitech G invented LIGHTSPEED wireless technology to deliver the ultimate in high-performance wireless gaming. LIGHTSPEED wireless technology is as fast or faster than many leading competitor's wired gaming mice. So you get the freedom of wireless with no compromises.
A Revolution in PC Gaming
With POWERPLAY and LIGHTSPEED technology, Logitech G has solved the barriers to high performance wireless gaming. Input lag, wireless disconnects, and dead batteries are now a thing of the past. Welcome to the future of wireless PC gaming, achieved through advanced science and unrivaled engineering -
POWERPLAY Charging Technology
Through innovative application of electromagnetic resonance, the POWERPLAY base creates an energy field above its surface. This allows charging while in motion and delivers wireless power without interfering with the precise measurement and data transmission of a high-performance gaming mouse. Integrating the technology into a 2mm thin form factor was no simple task. Enter: Logitech G -
POWERCORE Module
The POWERPLAY energy field is transformed into charging current by the POWERCORE module, which attaches magnetically to compatible wireless gaming mice. The beauty of POWERPLAY is that your mouse will charge while you're at play and at rest. We've made it that simple. It just stays charged. So, group up fearlessly, grind ranks, raid to your heart's content ... Repeat. Ad infinitum -
LIGHTSPEED Wireless Technology
Logitech G invented LIGHTSPEED wireless technology to deliver the ultimate in high-performance wireless gaming. LIGHTSPEED wireless technology is as fast or faster than many leading competitor's wired gaming mice. So you get the freedom of wireless with no compromises -
Cloth and Hard Gaming Mouse Pad
Tune your performance to your mouse pad of choice. We include both our cloth and hard surfaces so you can customize and swap interchangeably. POWERPLAY will suit your style right out of the box -
POWERPLAY Gaming Mice
The included POWERCORE module enables compatible wireless mice for POWERPLAY. It works with the all-new G903 and G703 wireless gaming mice. Easily swap in the magnetic POWERCORE module and you're ready to wirelessly charge -
Customizable RGB Lighting
Your G lights up in Brilliant RGB color. Use Logitech Gaming Software and set your lighting to match the rest of your gear with approximately 16.8 million colors. You can even synchronize color and lighting effects with Logitech G gaming mice, keyboards, and headsets for a unified look and feel. 1 More about Brilliant RGB Lighting -
Built-In Wireless
We designed POWERPLAY with a built-in LIGHTSPEED wireless receiver, so your gaming mouse can pair directly with the POWERPLAY base. This eliminates the need for an additional USB data receiver. You're Welcome
- Logitech Powerplay - mouse charging pad
- Mouse charging pad - external
- Included Accessories
- Hard gaming mouse pad (G440), cloth gaming mouse pad, POWERCORE module
- System Requirements
- Microsoft Windows 7 / 8 / 8.1 / 10
- 32.1 cm x 4.3 cm x 34.4 cm
- 2-year warranty
- 1 x USB 2.0 - 5 pin Micro-USB Type B
- Cables Included
- Micro-USB to USB cable - detachable - 1.83 m
- Integrated wireless receiver, POWERPLAY tehnology, LIGHTSPEED technology, 16.8 million RGB LED lights
- OS Required
- Limited warranty - 2 years
- 32.1 cm
- 4.3 cm
- 34.4 cm
