Seize the day with a joystick that keeps you at the top of your game. Optimal controls personalized for your unique gaming style. Whether you're in an acrobatic dogfight or striking from long range, the high-stability, precise Logitech Extreme 3D Pro gives you the edge on your competition. Experience superior response and control with 12 conveniently placed action buttons, eight-way rubberized hat switch, twist handle, and rapid-fire trigger.
                Precision twist rudder controlResearch has shown that advanced flying comes down to instincts and reaction time. To assist pilots, our lab boys designed a custom twist-handle rudder for Extreme 3D Pro, resulting in natural one-handed control with a smaller device footprint
                12 programmable buttonsExtreme 3D Pro has every command at your fingertips and exactly where you want it so you can keep your eyes on the horizon. Each programmable button can be configured to execute simple single commands or intricate macros involving multiple keystrokes, mouse events, and more
                8-way hat switchQuickly and easily switch from points of view to weapons and more-the 8-way hat switch is designed to accurately capture specialized input specific to flight sims
                Rapid-fire triggerPull the Extreme 3D Pro trigger as fast as you want or need, confident that every twitch of your finger will be captured without missing a beat
                Comfortable hand gripFly one more mission or take down more enemies in comfort, even after hours of action. Sculpted curves support and form to your hand for hours of comfortable flying
                Stable, weighted baseAn extensive study has shown that having a joystick sliding all over the place in the thick of the action is detrimental to performance. The heavy base will hold fast without tipping for lifting while you do your thing
- Logitech Extreme 3D Pro - joystick - wired
- Product Type
- Joystick
- Connectivity Technology
- Wired
- Buttons Qty
- 12
- Controls
- 8-way hat switch, triggers
- Handle rotation
- 3-year warranty
- Designed For
- PC
- Product Type
- Joystick
- Wired
- Buttons Qty
- 12
- Controls
- Interface
- USB
- Handle rotation
- OS Required
- Microsoft Windows Vista / 7 / 8
- Limited warranty - 3 years
- Designed For
- PC
