Logitech Extend - video/audio extender - USB-C, 10Mb LAN
Quicklinx: HZ4HWS00 Mfr#: 952-000199
23 In Stock
£657.44 ex VAT
£788.92 inc VAT
Single USB-C cable connection for BYOD meetings, deployed with category cabling, enables easy connection to a video conferencing system and display. Used for Android-based rooms with Microsoft Teams, Zoom Rooms, Google Meet, or for BYOD meeting rooms.
  • EASY BYOD MEETINGS
    With Logitech Extend, anyone can walk into an Android or BYOD-based meeting room, plug in with the USB-C cable, and launch a meeting from their laptop or mobile device
  • Quick connections. No Additional Drivers
    Use the USB-C cable to quickly plug in a laptop or mobile device and run meetings using a preferred video platform. No need to install additional software
  • BYOD PASSTHROUGH
    Use Extend in Android-based rooms with the Rally Bar family. It allows the meeting host to bypass the designated video provider and conduct the meeting from their own device
  • BYOD EXTENSION
    Use Extend for BYOD meetings with the Rally Bar family and other Logitech conference cameras by connecting a laptop or mobile device to conduct meetings using the in-room conference camera and display
  • FOR PC-BASED ROOMS
    Deploy Logitech Swytch for PC-based room solutions for a single-cable connection to the room's conference camera and display
  • EXTEND AND REACH
    Use category cabling to enable BYOD connections in larger rooms. 1. Table Side Box (TX) 2. Logitech Extend USB-C Connector 3. Optional power adapter 4. Category cable 5. Display Side Box (RX) 6. Rally Bar 7. Logitech Extend power 8. HDMI to camera or display 9. USB to camera 10. USB (additional)
  • ENABLE POWER DELIVERY TO DEVICES (optional)
    Deliver up to 100W of power to a laptop or mobile device by connecting a standard USB-C power adapter to the Table Side (TX) box. Power supply not included
  • SINGLE USB-C CABLE
    Single cable simplicity - no need for multiple cables, adapters, or dongles
  • MAGNETIC DOCK
    Rest the USB-C cable on the included magnetic dock for a clean tabletop
  • GROMMET ADAPTER
    Easily run the USB-C cable through tables with the included adapter
  • SIMPLE TO MANAGE
    View connectivity status and deploy updates via Logitech Sync, Logitech remote management software that supports video conferencing device management. Logitech Extend can also be updated using Zoom Device Management and Microsoft Teams Admin Center, as part of CollabOS device updates. Updates to Logitech Extend are deployed through Rally Bar family CollabOS updates. For other configurations, use the Sync app
  • A CHOICE YOU WILL FEEL GOOD ABOUT
    Logitech is committed to creating a more sustainable world and we are actively working to minimize our environmental footprint and accelerate the pace of social change
  • MADE WITH RECYCLED PLASTIC
    The plastic components in Logitech Extend include 40% certified post-consumer recycled plastic to give a second life to end-of-life plastic from old consumers electronics and help reduce our carbon footprint. Excludes plastic in printed wiring assembly (PWA), cables, and packaging
  • RESPONSIBLE PACKAGING
    The paper packaging of Logitech Extend comes from FSC -certified forests and other controlled sources. By choosing this product, you are supporting responsible management of the world's forests
Video/audio extender
External
USB-C, 10Mb LAN
Transmission Medium
CAT 5e/6
Max Transfer Distance
100 m
AC 100-240 V
Windows 10 / 11 or later, Apple macOS 13 or later
14.3 cm x 14.3 cm x 3.45 cm
External
Wired
USB-C, 10Mb LAN
Max Resolution
4K @ 60 Hz
100 m
4:4:4 chroma subsampling support, wall mountable, plastic housing, BYOD mode, DisplayPort Alternate mode
Encryption Algorithm
SHA-256
1 x HDMI - 19 pin HDMI Type A female , 2 x USB 2.0 - Type A female , 1 x micro-USB , 2 x Ethernet - RJ-45 , 1 x USB - Type C , 1 x USB (power input) - Type C
Grommet adapter (25.4 mm), magnetic dock
1 x power adapter - 1.5 m , 1 x USB-C 3.2 Gen 1 cable - 1.5 m , 1 x micro-USB to USB-A cable - 1 m
Mounting Kit
Included
FSC
External power adapter
AC 100-240 V
14.3 cm
14.3 cm
3.45 cm
Dimensions (WxDxH) / Weight Details
Power adapter: 7.35 cm x 5.3 cm x 3.5 cm
10 - 90%
