Logitech Extend - video/audio extender - USB-C, 10Mb LAN
Quicklinx: HZ4HWS00 Mfr#: 952-000199
10 In Stock
£621.87 ex VAT
£746.24 inc VAT
Single USB-C cable connection for BYOD meetings, deployed with category cabling, enables easy connection to a video conferencing system and display. Used for Android-based rooms with Microsoft Teams, Zoom Rooms, Google Meet, or for BYOD meeting rooms.
  • High-resolution video support
    The Extend supports a maximum video resolution of 4K, delivering sharp and detailed visuals.
  • Versatile connectivity options
    Featuring HDMI, USB 2.0, Ethernet, and micro-USB ports, this extender allows for flexible connections to various devices.
  • Durable and secure design
    Constructed with a plastic housing, the extender is designed to withstand regular use while the SHA-256 encryption algorithm ensures the security of your data.
  • User-friendly installation
    The included mounting kit enables easy wall-mountable installation, making it convenient to set up.
  • Wide operational range
    Operating efficiently in temperatures from 0°C to 40°C and humidity levels between 10% and 90%, this extender is prepared for various conditions.
Video/audio extender
External
USB-C, 10Mb LAN
Transmission Medium
CAT 5e/6
Max Transfer Distance
100 m
AC 100-240 V
Windows 10 / 11 or later, Apple macOS 13 or later
14.3 cm x 14.3 cm x 3.45 cm
External
Wired
USB-C, 10Mb LAN
Max Resolution
4K @ 60 Hz
100 m
4:4:4 chroma subsampling support, wall mountable, plastic housing, BYOD mode, DisplayPort Alternate mode
Encryption Algorithm
SHA-256
1 x HDMI - 19 pin HDMI Type A female , 2 x USB 2.0 - Type A female , 1 x micro-USB , 2 x Ethernet - RJ-45 , 1 x USB - Type C , 1 x USB (power input) - Type C
Grommet adapter (25.4 mm), magnetic dock
1 x power adapter - 1.5 m , 1 x USB-C 3.2 Gen 1 cable - 1.5 m , 1 x micro-USB to USB-A cable - 1 m
Mounting Kit
Included
FSC
External power adapter
AC 100-240 V
14.3 cm
14.3 cm
3.45 cm
Dimensions (WxDxH) / Weight Details
Power adapter: 7.35 cm x 5.3 cm x 3.5 cm
10 - 90%
Brand: Logitech
Price Range Ex VAT: £500 - £750
