Logitech ERGO M575 for Business - Trackball - Right Handed - Optical - Wireless - Graphite
Quicklinx: GYCBWS00 Mfr#: 910-006221
31 In Stock
£39.93 ex VAT
£47.91 inc VAT
Wireless trackball mouse engineered to reduce arm and hand fatigue.
  • SCIENTIFIC APPROACH
    We look at ergonomics from a scientific perspective to find that sweet spot between science, desirability, and comfort. Ergo Series keyboards and mice offer more natural postures, superior ergonomic benefits, and reduced movement or muscle strain in a familiar, easily adoptable form factor
  • MORE NATURAL POSTURE, LESS MUSCLE STRAIN
    Ergo products like ERGO M575 Trackball for Business place fingers and hands in a more natural posture, helping to relax the upper body. A more natural posture leads to a quantifiable reduction in muscle activity, so people can work just as productively while putting less strain on key muscles
  • INCREASED COMFORT
    Physical discomfort can lead to emotional stress. Reducing muscle strain while adding support leads to a greater level of comfort-immediately and over long periods. Ergonomic products make work more comfortable so people can be free to focus on what matters
  • ERGONOMICS IS ECONOMICS
    Ergonomic equipment helps people work more comfortably, with higher efficiency and quality, with less downtime. It results in happier employees with lower absentee days. In short, ergonomics is good economics. Our Ergo Series can help your company become a healthier place to work
  • IDEAL FOR
    People who want reduced wrist and hand movement People experiencing discomfort People who want comfort for long hours at the computer Anyone who works on small surfaces
  • AT A GLANCE
    View ERGO M575 Trackball for Business' ergonomic and productivity features
  • RECYCLED PLASTIC
    Graphite Plastics: 50% certified post-consumer recycled material Off-White Plastics: 21% certified post-consumer recycled material
  • BUILT FOR WORKFLOW
    Design Features Sculpted ergonomic shape with trackball
  • BUILT FOR WORKPLACE
    Design Benefits Super compact footprint ideal for tight workspaces
  • Minimal wrist & hand movement
    The sculpted ergonomic shape provides palm support while naturally fitting the hand. With no need to move the arm around to move the cursor, users experience 20% less muscle activity in the forearm, which helps the fingers, hand and arm stay more relaxed
  • Precision tracking
    Friction-free thumb control for excellent precision and responsiveness combined with a high-performance optical sensor delivers precise cursor movement and ultra low power consumption
  • Connect with Logi Bolt
    ERGO M575 Trackball for Business features Logi Bolt wireless technology, engineered to conquer IT challenges that can arise with both in-office and remote users. Delivering cross-platform compatibility and reliable wireless connections-even in congested wireless environments. Fully encrypted and FIPS secure when paired with a Logi Bolt USB receiver
  • FEATURES THAT DELIVER
    The ergonomic design allows ERGO M575 Trackball for Business to naturally fit a large range of hand sizes. Plus, it's perfect for tight spaces, busy desks, and most surfaces
  • TWO WAYS TO CONNECT
    Two connection options: Bluetooth Low Energy wireless technology or Logi Bolt-a tiny USB receiver designed for security and high performance even in congested wireless environments. Now users have the flexibility to connect how they want while IT ensures those connections are reliable and secure
  • MULTI-OS COMPATIBILITY
    Compatible with Windows , macOS , Linux , ChromeOS , and iPadOS . Logi Bolt wireless connectivity makes ERGO M575 Trackball for Business more universally compatible than most leading peripheral brands on the market
  • EASY TO MAINTAIN
    The innovative sensor performs its best with ultralow battery consumption. Remains powered up to 20 months on a single AA battery. Plus, the trackball is removable for easy cleaning
  • QUALITY THAT LASTS
    ERGO M575 Trackball for Business is durable and reliable. With Swiss engineering and end-to-end control of the production process, it's designed to perform for more than 3 million quality clicks
  • MADE WITH RECYCLED PLASTIC
    The plastic parts in ERGO M575 Trackball for Business include post consumer recycled plastic-50% for Graphite and 21% for Off-White-to give a second life to end-of-life plastic and help reduce our carbon footprint
Logitech Ergo Series ERGO M575 for Business - trackball - Bluetooth - graphite
Trackball
Wireless - Bluetooth
Graphite
Orientation
Right-handed
10 cm x 4.8 cm x 13.4 cm
145 g
Wireless Receiver
Logitech Logi Bolt USB receiver
Movement Detection Technology
Optical
Buttons Qty
5
Movement Resolution
4000 dpi
Performance
Realtime sensitivity switching 380 - 4000 dpi
Scrolling wheel, Thumb Control, Easy-Switch technology
AA type
Windows 10 or later, Apple macOS 10.14 or later, Linux, Google Chrome OS, Apple iPadOS 13.4 or later, Apple macOS 10.15 or later
Trackball
Wireless Receiver
Orientation
Right-handed
10 cm
4.8 cm
13.4 cm
145 g
Graphite
Input Device
Wireless
Bluetooth
Max Operating Distance
Up to 10 m
Optical
Buttons Qty
5
Movement Resolution
4000 dpi
Performance
1 x USB - 4 pin USB Type A
1 AA battery
AA type
Brand: Logitech
