Logitech ERGO M575 - Trackball Optical - 5 buttons
Quicklinx: GNJ5WS00 Mfr#: 910-005872
Wired / Wireless: Wireless
Colour: Graphite
£45.64 ex VAT
£54.76 inc VAT
Minimize movement and maximize comfort with ERGO M575 – a wireless trackball with a sculpted ergonomic shape. With no need to move your arm around to move the cursor, your hand and arm stay relaxed. The smooth and responsive thumb control can be used anywhere – and since it doesn't need to be moved – ERGO M575 is perfect for tight desk spaces.
  • WORK IN YOUR COMFORT ZONE
  • SHAPED FOR HANDS LIKE YOURS
    ERGO M575 has been designed and developed to ergonomically fit the shape of your hand. And with no need to move your arm around to move the cursor you'll reduce fatigue in your hand and arm
  • THUMBS UP FOR THUMB CONTROL
    Get on a more ergonomic track with exceptionally precise trackball control. Your thumb will glide across the smooth ball surface with total ease thanks to transparent finish coating. And the high-performance optical sensor matches great accuracy with ultra-low power consumption
  • MORE SPACE FOR ALL YOUR (AWESOME) STUFF
    ERGO M575 features a super compact footprint since it doesn't move to control the cursor. It's ideal for tight workspaces, or for those of us that have desks full of papers, personal items – and sometimes even a bowl of cereal
  • EASY CONNECT WITH WINDOWS AND MAC
    With two ways to connect – via Bluetooth Low Energy or the included USB receiver – ERGO M575 provides a powerful, reliable signal from up to 10 m away.1Wireless range may vary depending on operating environment and computer set up Connect to either Windows or macOS and never worry about drop-offs or laggy connections
  • QUALITY THAT LASTS
    ERGO M575 is durable and reliable. With Swiss engineering and end-to-end control of the production process, it's designed to perform for more than 3 million quality clicks
  • MADE WITH RECYCLED PLASTIC
    The plastic parts in ERGO M575 include post consumer recycled plastic - 50% for Graphite and 21% for Off-White - to give a second life to end-of-life plastic and help reduce our carbon footprint
  • DESIGNED FOR POWER EFFICIENCY
    The innovative sensor performs its best with ultralow battery consumption. Stay powered up to 2 years on a single AA battery
  • RESPONSIBLE PACKAGING
    The paper packaging of the ERGO M575 comes from FSC -certified forests. By choosing this product, you are supporting responsible management of the world's forests
  • UP TO 24-MONTH BATTERY LIFE
    Stay powered up to 2 years on a single AA with the included Unifying USB receiver and up to 20 months using Bluetooth Low Energy
  • CONVENIENT CONTROLS
    Moving between documents or browser tabs is a breeze with large, easy-to-reach Back/Forward buttons
  • EASY TO CLEAN
    Should you need to clean your trackball, removing and wiping down the ball is a snap
  • ERGO SETUP ONBOARDING
    Set up your trackball – and your entire workstation – for better ergonomics with the Logitech Ergo onboarding
  • MAKE SPACE FOR COMFORT
    Make any workspace your comfort zone. This compact setup has the tools you need for all-day comfort and better productivity-from a minimalist keyboard and trackball combo to the right webcam and wireless headset to feel great during calls
Logitech Ergo Series ERGO M575 - trackball - Bluetooth 5.0 LE, 2.4 GHz - graphite
Trackball
Wireless - Bluetooth 5.0 LE, 2.4 GHz
Graphite
10 cm x 4.8 cm x 13.4 cm
145 g
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Buttons Qty
5
Movement Resolution
2000 dpi
Scrolling wheel, Thumb Control
AA type
Microsoft Windows 7 / 8 / 10 or later, Apple macOS 10.13 or later, Apple iPadOS 13.4 or later
Trackball
Wireless Receiver
10 cm
4.8 cm
13.4 cm
145 g
Graphite
Input Device
Wireless
Max Operating Distance
Up to 10 m
Optical
Buttons Qty
5
Movement Resolution
2000 dpi
1 x USB - 4 pin USB Type A
1 AA battery
AA type
Colour: Graphite
Brand: Logitech
