Logitech Ergo K860 - Graphite - UK - 2.4GHZ/Bluetooth 5.0 - QWERTY
Quicklinx: GC1TWS00 Mfr#: 920-010107
Wired / Wireless: Wireless
Colour: Graphite
Compatibility: Mac, PC
More than 50 In Stock
£84.75 ex VAT
£101.70 inc VAT
Introducing ERGO K860, a split ergonomic keyboard designed for better posture, less strain, and more support. You'll type more naturally with a curved, split keyframe that improves typing posture. The sloping form reduces muscle strain on your wrists and forearms - keeping your hands and shoulders relaxed.
ERGO K860's curved keyframe places your hands, wrists, fingers and forearms in a more natural posture - you'll notice the lack of strain the moment your hands land on the keyboard. ERGO K860 has even been proven to reduce muscle activity by 21% in the upper trapezius muscle - a key muscle in the center of the back that stabilizes and facilitates shoulder and neck movement.
  • A FEEL-BETTER TYPING EXPERIENCE
    Introducing ERGO K860, a split ergonomic keyboard designed for better posture, less strain, and more support. You'll type more naturally with a curved, split keyframe that improves typing posture. The sloping form reduces muscle strain on your wrists and forearms – keeping your hands and shoulders relaxed
  • BETTER POSTURE, BETTER RESULTS
    ERGO K860's curved keyframe places your hands, wrists, fingers and forearms in a more natural posture – you'll notice the lack of strain the moment your hands land on the keyboard. ERGO K860 has even been proven to reduce muscle activity by 21% in the upper trapezius muscle - key muscle in the center of the back that stabilizes and facilitates shoulder and neck movement
  • THREE LAYERS OF COMFORT AND SUPPORT
    A pillowed wrist rest places your forearms just above the keyboard, offering 54% more wrist support while reducing wrist bending by 25%. 1. SURFACE LAYER: 0.02 in (0.5 mm) of KNITTED FABRIC with a durable, stain-resistant, and easy-clean coating that's smooth to the touch. 2. SUPPORT LAYER: 0.079 in (2 mm) HIGH-DENSITY FOAM provides a comfortable, firm feel that equally disperses pressure. 3. COMFORT LAYER: 0.157 in (4 mm) of MEMORY FOAM offers a pleasing and personalized give, improving the feel of comfort and relaxation
  • GIVE YOUR WRISTS A LIFT
    Keep your wrists in a natural and comfortable posture, whether you're seated or standing with an innovative palm lift feature. Tilt legs of 0°, -4°, and -7° lift your palms into the optimal ergonomic position depending on your unique set up
  • EFFORTLESS PRECISION WITH PERFECT STROKE KEYS
    A fluid and ultra-precise typing experience with no compromise in speed and accuracy. Your fingers glide effortlessly across the matte surface of the keys, and tactile details make it easy to orient your fingers and stay focused. The split layout and convex curve promote a more natural hand and finger placement
  • WORK BETTER. WORK HEALTHIER
    Perform at your best with the Advanced Ergonomic Solution that includes an ergonomic keyboard and mouse combo-plus the right webcam and headset for good posture during calls
Logitech ERGO K860 - keyboard - QWERTY - UK - graphite Input Device
Keyboard - ergonomic (split)
2.4 GHz, Bluetooth 5.0
Wireless Receiver
USB wireless receiver
Wireless
Localization and Layout
QWERTY UK
Numeric Keypad
Graphite
45.6 cm x 23.3 cm x 4.8 cm
1.16 kg
Max Operating Distance
Up to 10 m
Wireless Receiver
Wireless
QWERTY UK
Adjustable Height
Palm Rest
Numeric keypad
45.6 cm
23.3 cm
4.8 cm
1.16 kg
Graphite
Microsoft Windows 7 or later, Apple MacOS 10.11 or later
AAA type
Installed Qty
2
Required Qty
2
Colour: Graphite
Compatibility: Mac
Compatibility: PC
Brand: Logitech
