Enjoy total control of your PC entertainment from your sofa. Palm-sized, cordless mini-keyboard fits in your hand and gives you optimal control and access of the PC entertainment you love, including browsing the Internet, watching TV, listening to music and playing PC games. Dedicated Windows Media Center controls optimize launch and navigation of Microsoft's popular entertainment platform. Integrated, dual-purpose ClickPad enhances control and access with innovative technology that can be used as a touch pad and a directional pad. Rechargeable Li-ion batteries give you up to one month of battery life. Bluetooth wireless technology provides long-range wireless control from up to 10 m (30 ft). Backlighting makes text entry effortless, even in low light.
- Logitech diNovo Mini - keyboard - UK - silver, midnight black Input Device
- Keyboard
- Backlit
- Interface
- Bluetooth
- Wireless Receiver
- USB wireless receiver
- Connectivity Technology
- Wireless
- Localization and Layout
- UK
- Hot Keys Qty
- 63
- Dual-purpose ClickPad
- Silver, midnight black
- 15.2 cm x 9 cm x 2.8 cm
- 170 g
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Keyboard
- Backlit
- Interface
- Bluetooth
- Max Operating Distance
- Up to 10 m
- Wireless Receiver
- Wireless
- Hot Keys Qty
- 63
- UK
- Region
- United Kingdom
- 15.2 cm
- 9 cm
- 2.8 cm
- 170 g
- Connections
- 1 x USB - 4 pin USB Type A
- Included Accessories
- AC power adaptor, cleaning cloth
- Compatibility
- MS Windows XP Media Centre compatible
- OS Required
- Microsoft Windows XP, Microsoft Windows Vista
- Installed Qty
- 1
- Technology
- Lithium Ion
- Limited warranty - 3 years
Customer reviews
Write a review for the Logitech diNovo Mini Dual Purpose ClickPad - USB Wireless Receiver here!
Dinovo mini
Reviewed by Anonymous Review Posted 29/05/2008
having received this today and just had a brief play, i found myself being very impressed! It looks stunning, feels good to hold and seems very well built. would recommend to anyone planning to use this to control media center (havent tried on the ps3 yet). overall I would have to say worth the money, even though it is a lot of cash for a keyboard.
Serious thumbs up!
Overall
Ease of use
Value for money
Close but no cigar... avoid.
Reviewed by James. Review Posted 05/01/2009
Ah the perfect media keyboard? Small, sleek, excessively cool?
Almost.
First things first, its a fingerprint magnet, & from a usability point of view, the keyboard is terrible. There are no raised dots on the home keys (F & J) so touchtyping is impossible, and it's hard to tell the difference between different keys as they are convex, as opposed to the concave keys on most keyboards, meaning your fingers easily slip onto the wrong key.
Unfortunately mine exhibits the same issues as the person above me stated. Bluetooth regularly drops out and the keyboard becomes useless, with only the touchpad working. To fix it you have to remove and reinsert the battery.
The bluetooth issues might be fixed by the time you get yours, but they keyboard problems are always going to be there... I'd look elsewhere.
P.S. Why can Apple make an incredibly small, attractive aluminium bluetooth keyboard for £50, but Logitech make a small plastic one and it costs £75?!! That’s just wrong.
Overall
Ease of use
Value for money
Nearly thier
Reviewed by Anonymous Review Posted 13/07/2008
This looked the perfect gizmo to control my home theatre PC and after installing worked well, apart from: difficult to open lid and the hinge pinches your fingers!, irritating mouse/remote mode switch, bluetooth connection fails regularily so have to keep removing keyboard battery. All in all a beautifully designed but insifficiently tested product.
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
