Logitech Desktop MK120 - Keyboard & Mouse - USB
Desktop MK120
Quicklinx: 76BMWS00 Mfr#: 920-002552
Recommended Use: Leisure
Type: Keyboard
Wired / Wireless: Wired
Colour: Black
Compatibility: PC
26 left in stock
£15.83 ex VAT
£18.99 inc VAT
Express delivery Order within the next 17 hours for delivery tomorrow
Logitech Desktop MK120 is a durable duo that brings comfort, style and simplicity together. You'll be comfortable with the keyboard thanks to the low-profile, whisper-quiet keys and standard layout with full-size F-keys and number pad. With its thin profile, spill-resistant design, durable keys that can withstand up to 10 million keystrokes and sturdy, adjustable tilt legs, this sleek keyboard not only looks and feels good - it's built to last. Plus, it's got easy-to-read keys. The high-definition optical mouse puts comfort and control in your hands with smooth, accurate tracking and a comfortable, ambidextrous shape. And setup is simple - you just plug your keyboard and mouse into USB ports and start using them right out of the box.
With a sleek, comfortable keyboard and high-definition optical mouse, this durable duo brings comfort, style and simplicity together
Comfortable, quiet typing
You'll enjoy a comfortable and quiet typing experience thanks to the low-profile keys that barely make a sound and standard layout with full-size F-keys and number pad.
Spill-resistant design
Liquid drains out of the keyboard, so you don't have to worry about ruining your investment with accidental spills.
High-definition optical tracking
You'll enjoy responsive and smooth cursor control with the high-definition optical tracking (1000 dpi).
Thin profile
The keyboard has a thin profile that adds a sleek look to your desk while keeping your hands in a more comfortable, neutral position.
Durable keys
The keys can last up to 10 million keystrokes so you can keep typing long after many keyboards have called it quits.
Plug-and-play USB connections
Setup is simple--you just plug your keyboard and mouse into USB ports on your desktop, laptop or netbook computer and start using them right out of the box.
Easy-to-read keys
The bold, bright white characters make the keys easier to read--perfect for those with less-than-perfect vision. They're less likely to wear off, too.
Sturdy, adjustable tilt legs
You can extend the sturdy folding legs to increase the keyboard tilt by 8 degrees to address your personal ergonomic needs.
Curved space bar
It keeps your hands in a more natural position so you can type in greater comfort.
Logitech reliability
You get the high quality and reliability that's made Logitech the global leader for keyboards and mice at a price you can afford--plus a 3-year warranty.
  • FULL-SIZED KEYBOARD
    This full-size keyboard with integrated number pad makes data entry, calculations and navigation a breeze. The curved spacebar along with easy-to-read keys provide a comfortable and familiar typing experience
  • COMFORT FOR EITHER HAND
    A full-sized, ambidextrous mouse delivers smooth tracking and a curved shape to support the palm, for easy and comfortable navigation
  • EASY PLUG & PLAY
    Both the keyboard and mouse work right out of the box. Just plug into the USB ports, and they're ready to go. No downloads, no setup, no fuss
  • SPILL RESISTANT KEYBOARD
    With a spill-resistant design Tested under limited conditions (maximum of 60 ml liquid spillage). Do not immerse the keyboard in liquid. , durable keys, and sturdy tilt legs with adjustable height, this keyboard is built to last
  • RELIABLE AND DURABLE
    With an included 3-year warranty, MK120 is built with the same high quality and reliability standards that have made Logitech the #1 global leader for mice and keyboards Based on independent sales data (in units) aggregated for Logitech mice and keyboards from major global markets including Canada, China, France, Germany, Indonesia, Republic of Korea, Russian Federation, Sweden, Taiwan,Turkey, UK, US (July '19 - July '20 period). Retail channel only.
  • DECADES OF DESIGN EXPERTISE
    With more than 22 years experience designing high-quality keyboards and mice, we carefully design, develop, prototype, and study all the essential components of our devices, from the core technologies to the comfort and ergonomics of their design. We strive to provide each individual with their ideal typing and navigation experience, according to their stature, lifestyle and deskspace
  • FOR SCHOOLS
    The simple addition of a mouse can help students move around apps, the web and more with greater ease. A full-size keyboard gives them a familiar platform and easy access to the controls and number keys they often need. The result? Efficiency and control that builds confidence and supports engaged learning
  • FOR BUSINESS
    A durable duo that brings comfort, style, and simplicity together. Most are instantly comfortable with the classic keyboard thanks to easy-to-read keys and standard full-size layout. And the high-definition optical full-size mouse puts comfort and control in hands with smooth, accurate tracking and a comfortable, ambidextrous shape
  • FOR SCHOOLS
Logitech Desktop MK120 - keyboard and mouse set - English Input Device
Keyboard and mouse set
USB
Wired
Localization and Layout
English
Spillproof, tilt legs
Pointing Device
Mouse - optical
Scrolling wheel, 1000 dpi resolution
3-year warranty
USB
English
Pointing Device
Mouse
Movement Detection Technology
Optical
Pointing Device Features
2 x USB cable
Included Software
Drivers & Utilities
Linux Kernel 2.6 or later, Microsoft Windows Vista / XP / 7
Limited warranty - 3 years
Type: Keyboard
Colour: Black
Compatibility: PC
Brand: Logitech
Stock Status: While stocks last
Stock Status: Clearance
