Logitech Create Case Ipad Pro 12.9" Black
Quicklinx: CB16WS00 Mfr#: 939-001417
Beautiful protection. Any angle viewing. Whatever you do, you have 60-degrees of viewing angles to choose from.
  • AnyAngle stand
    Get the perfect perspective whether you're watching videos, playing games or working with Apple Pencil. CREATE lets you adjust your viewing angle of iPad Pro anywhere along a 60-degree range instead of fixed positions. A smooth-glide hinge means the angle stays put until you change it
  • Exclusive micro-hinge system
    A smooth-glide hinge ensures you can set iPad Pro precisely at the angle you want, within a 60 degrees range. Once the angle is set, the hinge keeps it firmly in place until you decide to change it
  • Beautiful all-around protection
    Careful attention to color, materials and finish means CREATE is both beautiful and protective. The custom-sculpted curves inside provide structural integrity to protect your iPad Pro. Outside, a tightly woven premium fabric resists bumps, scratches, and spills
  • Auto wake, auto sleep
    Open CREATE and your iPad Pro wakes up, ready to rock. Close the case and it's time to sleep, saving battery life for your next inspiration
Logitech CREATE - flip cover for tablet
Flip cover for tablet
22.8 cm x 1.48 cm x 31.5 cm
521 g
Apple 12.9-inch iPad Pro (1st generation, 2nd generation)
22.8 cm
1.48 cm
31.5 cm
521 g
Carrying Case
Protective cover
Recommended Use
For tablet
Protection
Scratch-resistant
Cover Type
Flip cover
Open Type
Side
Cover Features
Stand function
2 years
