Beautiful protection. Any angle viewing. Whatever you do, you have 60-degrees of viewing angles to choose from.
AnyAngle stand
Get the perfect perspective whether you're watching videos, playing games or working with Apple Pencil. CREATE lets you adjust your viewing angle of iPad Pro anywhere along a 60-degree range instead of fixed positions. A smooth-glide hinge means the angle stays put until you change it -
Exclusive micro-hinge system
A smooth-glide hinge ensures you can set iPad Pro precisely at the angle you want, within a 60 degrees range. Once the angle is set, the hinge keeps it firmly in place until you decide to change it -
Beautiful all-around protection
Careful attention to color, materials and finish means CREATE is both beautiful and protective. The custom-sculpted curves inside provide structural integrity to protect your iPad Pro. Outside, a tightly woven premium fabric resists bumps, scratches, and spills -
Auto wake, auto sleep
Open CREATE and your iPad Pro wakes up, ready to rock. Close the case and it's time to sleep, saving battery life for your next inspiration
- Logitech CREATE - flip cover for tablet
- Product Type
- Flip cover for tablet
- 22.8 cm x 1.48 cm x 31.5 cm
- 521 g
- Black
- 2-year warranty
- Designed For
- Apple 12.9-inch iPad Pro (1st generation, 2nd generation)
- 22.8 cm
- 1.48 cm
- 31.5 cm
- 521 g
- Black
Carrying Case
- Protective cover
- Recommended Use
- For tablet
- Protection
- Scratch-resistant
- Cover Type
- Flip cover
- Open Type
- Side
- Cover Features
- Stand function
- 2 years
- Designed For
