Logitech Crayon - Digital pen - wireless - grey
Quicklinx: GXMTWS00 Mfr#: 914-000052
Device Type: iPad
Type: Stylus
Device Screen Size: [N/A]
Colour: Grey
£58.33 ex VAT
£69.99 inc VAT
Logitech Crayon is a versatile, pixel-precise digital pencil for all iPads (2018 and later) that lets you unleash your creativity. Mark up PDFs, take handwritten notes, or doodle a masterpiece - Logitech Crayon works with apps that support Apple Pencil. And with hundreds of Apple Pencil supported apps available right now, you can start learning, collaborating, and creating on iPad instantly.
  • DIGITAL LEARNING
    Unleash what's possible for students of all ages using innovative educational apps. Crayon empowers them to write, create, and learn at home or in the classroom - and yes, that includes lefties!
  • WORK PROFESSIONALS
    Step up your work game with a tool that allows you to supercharge your productivity whether you're working from home, or back in the office
  • UPGRADE YOUR NEXT PROJECT
    Stop settling for average, unleash your creativity and bring personal projects to the next level with Logitech Crayon
  • PRECISELY ON POINT
    With zero perceptible lag time and precision down to the pixel, just write and draw naturally without fear of missing a single line or detail
  • THE PERFECT LINE EVERY TIME
    Need a thicker or thinner line? Just tilt. A smart tip dynamically adjusts line weight depending on the angle you place it down - just like a regular pencil
  • University Students
    Take lecture notes, sketch lab diagrams, and collaborate remotely
  • Middle & High School
    Toss it in a backpack to take class notes, illustrate concepts in STEM classes, or collaborate with classmates
  • Elementary
    Helps younger students write, draw, and even converts hand-written notes to text with Scribble
  • Sign Documents & Markups
    Add hand-written signatures to documents for an extra touch of professionality
  • Enhance Your Designs
    Bring hand-drawn illustration and type to family newsletters, personal websites, and more
  • Homemade Gifts
    Add a personal touch to DIY projects and crafts with hand-drawn images and logos
  • Digital Creation
    Get more done with an intuitive analog tool that's easy to grasp and use
  • SETUP RESOURCES
    Updating iOS on your iPad may affect your ability to enjoy the full functionality of certain apps with Crayon. If you notice changes in your experience, update your Crayon's firmware here
  • REPLACEMENT PARTS
    Replace a worn down or broken Logitech Crayon tip to ensure you're getting the most from your digital pencil and iPad
  • Simple Comfort Possible
    Lightweight, comfortable and convenient with easy flip-to-mute feature. Stay cool with open air around your ears
Logitech Crayon - digital pen - grey
Digital pen
Wireless
Grey
1.2 cm x 0.8 cm x 16.3 cm
20 g
Rechargeable battery, 1.2 m drop protection, automatic power off, charging LED Indicator, on/off power switch, tilt sensitive, Palm Rejection Technology
Digital pen
1.2 cm
0.8 cm
16.3 cm
20 g
Product Material
Aluminium, silicone rubber, PC/ABS
Grey
Input Device
Wireless
1 x Lightning - Apple Lightning
Lithium polymer
Run Time (Up To)
7.5 hour(s)
Device Type: iPad
Type: Stylus
Colour: Grey
Brand: Logitech
