With hyper-fast scrolling, you control the pace. Fly through long documents and Web pages with a single flick. Or switch to click-to-click mode for precise, line-by-line navigation.
Hyper-fast scrolling
In free-spinning mode you can coast smoothly through the longest documents and Web pages. In click-to-click mode you can step precisely through spreadsheets, photo albums or playlists -
Precise laser tracking
Experience smoother cursor control on virtually any surface. Work faster and more accurately than with an ordinary optical mouse -
Comfortable, contoured design
Soft side grips and a contoured design support your hand naturally for all-day comfort and confident control -
Two thumb buttons
The thumb buttons come programmed to let you move back and forth through Web pages or photo albums, but can be configured to do exactly what you want them to -
Plug-and-play setup
Your mouse works right out of the box. No installation hassles. No software required. Just plug the cord into a USB port and you're good to go -
Superior scrolling. Powerful pointing
Our Hyper-fast scroll wheel and a precise laser sensor make this mouse one very capable companion -
Hour-after-hour comfort
Perfectly sized and subtly contoured, the sculpted design gives you the support you need for work or for play -
Extra control right where you need it
Two customizable thumb buttons make it simpler and faster to get things done
- Logitech M500 - mouse - USB
- Mouse
- Connectivity Technology
- Wired - USB
- Movement Detection Technology
- Laser
- Scrolling wheel, soft rubber grip
- OS Required
- Apple MacOS X 10.4 or later, Microsoft Windows Vista / XP / 7 / 8
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Mouse
Input Device
- Wired
- Interface
- USB
- Laser
- 1 x USB - 4 pin USB Type A
- Plug and Play
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - 3 years
