Logitech Corded Mouse M500
Quicklinx: BGYVWS00 Mfr#: 910-003726
With hyper-fast scrolling, you control the pace. Fly through long documents and Web pages with a single flick. Or switch to click-to-click mode for precise, line-by-line navigation.
  • Hyper-fast scrolling
    In free-spinning mode you can coast smoothly through the longest documents and Web pages. In click-to-click mode you can step precisely through spreadsheets, photo albums or playlists
  • Precise laser tracking
    Experience smoother cursor control on virtually any surface. Work faster and more accurately than with an ordinary optical mouse
  • Comfortable, contoured design
    Soft side grips and a contoured design support your hand naturally for all-day comfort and confident control
  • Two thumb buttons
    The thumb buttons come programmed to let you move back and forth through Web pages or photo albums, but can be configured to do exactly what you want them to
  • Plug-and-play setup
    Your mouse works right out of the box. No installation hassles. No software required. Just plug the cord into a USB port and you're good to go
  • Superior scrolling. Powerful pointing
    Our Hyper-fast scroll wheel and a precise laser sensor make this mouse one very capable companion
  • Hour-after-hour comfort
    Perfectly sized and subtly contoured, the sculpted design gives you the support you need for work or for play
  • Extra control right where you need it
    Two customizable thumb buttons make it simpler and faster to get things done
Logitech M500 - mouse - USB
Mouse
Wired - USB
Movement Detection Technology
Laser
Scrolling wheel, soft rubber grip
Apple MacOS X 10.4 or later, Microsoft Windows Vista / XP / 7 / 8
Microsoft Certification
Compatible with Windows 7
3-year warranty
Mouse
Input Device
Wired
USB
Laser
1 x USB - 4 pin USB Type A
Plug and Play
Software Included
Drivers & Utilities
Limited warranty - 3 years
