Logitech ConferenceCam CC3000e - conference camera
Quicklinx: 972NWS00 Mfr#: 960-000983
Turn any meeting space into a video-enabled collaboration place. By using your familiar computing environment and UC application of choice, the CC3000e is Plug-and-Play and easy to deploy. Workgroups of 6-10 people can now experience the productivity benefits of crystal-clear face-to-face communication.
  • Enhanced audio clarity
    With built-in dual stereo microphones, the Logitech ConferenceCam CC3000e ensures every participant in the room is heard with crystal clear clarity, making every meeting more productive.
  • High-definition video
    Capture every detail with the Logitech ConferenceCam CC3000e, which offers a max digital video resolution of 1920 x 1080. The Full HD video brings remote participants into the room, making it feel like everyone's together, regardless of their location.
  • Versatile connectivity
    The Logitech ConferenceCam CC3000e's USB 2.0 interface provides easy and reliable connectivity to a PC, ensuring seamless integration into a variety of conference room setups without the need for complex configurations.
  • Dynamic viewing angles
    Equipped with a panning range of 260 degrees and a tilting range of 130 degrees, the Logitech ConferenceCam CC3000e offers flexible viewing angles, making it easy to adjust the camera to fit the meeting's needs.
Conference camera
Audio
Yes: built-in dual stereo microphones
13 cm x 13 cm x 15 cm
590 g
Wired
Camera
Max Resolution
1920 x 1080
Panning Range (degree)
260
Tilting Range (degree)
130
USB 2.0
Skype compatible
Conference camera
Audio Support
Wired
13 cm
13 cm
15 cm
590 g
Camera
Max Digital Video Resolution
1920 x 1080
Video Capture
1920 x 1080 @ 30 fps
Skype compatible
Panning
Range (degree)
260
Tilting
Range (degree)
130
Computer Interface
USB 2.0
1 x USB 2.0 - 4 pin USB Type A
Remote control, speakerphone
