Logitech Conference Cam BCC950
Quicklinx: 85Q3WS00 Mfr#: 960-000867
£168.93 ex VAT
£202.71 inc VAT
It combines HD 1080p 30fps video with high-quality full-duplex speakerphone clarity for business-grade video conferencing. UVC H. 264 onboard technology helps ensure quick Plug-and-Play functionality on both PCs and Macs - no software to install. The built-in, full duplex speakerphone and noise-canceling microphone allow all meeting members to hear and be heard clearly up to 8 feet away from the base.
  • ALL-IN-ONE DESIGN
    Just plug and play. BCC950 delivers wideband audio from a full duplex speakerphone and HD video from a motorized camera. In other words, it's everything you need to conduct a small video conference with up to 4 people in one room
  • PERFECT FOR PRODUCTIVE TEAMS
    With a compact footprint and motorized eye-level camera, BCC950 is designed with small groups in mind. An omni-directional speaker and noise-cancelling microphone allow all meeting members to clearly hear and be heard up to 8 feet away. BCC950 is designed for use in private offices, home offices, or virtually any semi-private space
  • COMPATIBLE WITH MOST VC APPS
    BCC950 offers a plug-and-play USB connection to Windows and Mac computers, and works with most any video conferencing application, including Skype for Business, Zoom, BlueJeans, Broadsoft, Cisco Jabber , Fuze, LifeSize Cloud, and Vidyo
  • SEE EYE-TO-EYE
    Eye contact helps you make better connections, especially when you need to establish a new relationship, support a client, or collaborate with a distributed team. Thanks to a motorized camera and innovative extender stem, BCC950 makes video conferencing feel easy and natural
  • NATURAL SOUND
    With acoustic echo cancellation and noise canceling technology, BCC950 suppresses distracting background noises and annoying echo so voices sound clear and natural. Enjoy room-filling sound from the full-range speaker, or plug in your earbuds for privacy
  • HANDHELD REMOTE CONTROL
    Control BCC950's camera and audio on the speakerphone or from across the room with the handheld remote control. Either way, that all-important mute button stays in easy reach
  • USB Plug-and-Play Connectivity
    With no special software, training, or maintenance required, videoconferencing has never been easier. There's nothing to configure or install: simply plug BCC950 into your PC or Mac and join your meeting
  • Quality Optics
    BCC950 features quality optics so you enjoy bright, clear video with accurate color rendition and sharpness. Pan 180° across the room, and zoom in up to 1.2x in HD or 4x in SD to focus on the details
Logitech BCC950 ConferenceCam - webcam
Webcam - pan / tilt / zoom
Audio
Yes: built-in speaker, built-in microphone
10.4 cm x 15 cm x 15.4 cm
231 g
Wired
Camera
Max Resolution
1920 x 1080
Focus Adjustment
Automatic
Panning Range (degree)
180
Tilting Range (degree)
55
USB 2.0
1 - USB cable - 2.4 m
USB 2.0 compatibility, Carl Zeiss optics, Skype compatible
Microsoft Certification
Compatible with Windows 7
Webcam
Audio Support
Wired
10.4 cm
15 cm
15.4 cm
231 g
Camera
Colour - pan / tilt / zoom
Digital Video Format
H.264
Max Digital Video Resolution
1920 x 1080
Video Capture
1920 x 1080 @ 30 fps
Lens Construction
Focus Adjustment
Automatic
Panning
Range (degree)
180
Tilting
Range (degree)
55
Computer Interface
USB 2.0
Interfaces Details
1 x headset - mini-phone 3.5 mm , 1 x USB 2.0 - 4 pin USB Type A
Remote control
1 x USB cable - 2.4 m
Power adapter - external
Apple MacOS X 10.7 or later, Microsoft Windows 7 / 8.1 / 10
Shipping Width
17.7 cm
Shipping Depth
17.3 cm
Shipping Height
12.4 cm
Shipping Weight
1.103 kg
Brand: Logitech
