It combines HD 1080p 30fps video with high-quality full-duplex speakerphone clarity for business-grade video conferencing. UVC H. 264 onboard technology helps ensure quick Plug-and-Play functionality on both PCs and Macs - no software to install. The built-in, full duplex speakerphone and noise-canceling microphone allow all meeting members to hear and be heard clearly up to 8 feet away from the base.
                ALL-IN-ONE DESIGNJust plug and play. BCC950 delivers wideband audio from a full duplex speakerphone and HD video from a motorized camera. In other words, it's everything you need to conduct a small video conference with up to 4 people in one room
                PERFECT FOR PRODUCTIVE TEAMSWith a compact footprint and motorized eye-level camera, BCC950 is designed with small groups in mind. An omni-directional speaker and noise-cancelling microphone allow all meeting members to clearly hear and be heard up to 8 feet away. BCC950 is designed for use in private offices, home offices, or virtually any semi-private space
                COMPATIBLE WITH MOST VC APPSBCC950 offers a plug-and-play USB connection to Windows and Mac computers, and works with most any video conferencing application, including Skype for Business, Zoom, BlueJeans, Broadsoft, Cisco Jabber , Fuze, LifeSize Cloud, and Vidyo
                SEE EYE-TO-EYEEye contact helps you make better connections, especially when you need to establish a new relationship, support a client, or collaborate with a distributed team. Thanks to a motorized camera and innovative extender stem, BCC950 makes video conferencing feel easy and natural
                NATURAL SOUNDWith acoustic echo cancellation and noise canceling technology, BCC950 suppresses distracting background noises and annoying echo so voices sound clear and natural. Enjoy room-filling sound from the full-range speaker, or plug in your earbuds for privacy
                HANDHELD REMOTE CONTROLControl BCC950's camera and audio on the speakerphone or from across the room with the handheld remote control. Either way, that all-important mute button stays in easy reach
                USB Plug-and-Play ConnectivityWith no special software, training, or maintenance required, videoconferencing has never been easier. There's nothing to configure or install: simply plug BCC950 into your PC or Mac and join your meeting
                Quality OpticsBCC950 features quality optics so you enjoy bright, clear video with accurate color rendition and sharpness. Pan 180° across the room, and zoom in up to 1.2x in HD or 4x in SD to focus on the details
- Logitech BCC950 ConferenceCam - webcam
- Webcam - pan / tilt / zoom
- Audio
- Yes: built-in speaker, built-in microphone
- 10.4 cm x 15 cm x 15.4 cm
- 231 g
- Connectivity Technology
- Wired
- Camera
- Max Resolution
- 1920 x 1080
- Focus Adjustment
- Automatic
- Panning Range (degree)
- 180
- Tilting Range (degree)
- 55
- USB 2.0
- Cables Included
- 1 - USB cable - 2.4 m
- USB 2.0 compatibility, Carl Zeiss optics, Skype compatible
- 2-year warranty
- Microsoft Certification
- Compatible with Windows 7
- Webcam
- Audio Support
- Wired
- 10.4 cm
- 15 cm
- 15.4 cm
- 231 g
Camera
- Colour - pan / tilt / zoom
- Digital Video Format
- H.264
- Max Digital Video Resolution
- 1920 x 1080
- Video Capture
- 1920 x 1080 @ 30 fps
Lens Construction
- Focus Adjustment
- Automatic
Panning
- Range (degree)
- 180
Tilting
- Range (degree)
- 55
- Computer Interface
- USB 2.0
- Interfaces Details
- 1 x headset - mini-phone 3.5 mm , 1 x USB 2.0 - 4 pin USB Type A
- Included Accessories
- Remote control
- Cables Included
- 1 x USB cable - 2.4 m
- Power Device
- Power adapter - external
- OS Required
- Apple MacOS X 10.7 or later, Microsoft Windows 7 / 8.1 / 10
- Limited warranty - 2 years
- Shipping Width
- 17.7 cm
- Shipping Depth
- 17.3 cm
- Shipping Height
- 12.4 cm
- Shipping Weight
- 1.103 kg
