The Logitech Combo Touch keyboard case provides form-fit protection for iPad. The Multi-Touch trackpad enables precise navigation and a detachable keyboard offers flexibility for different tasks. Users can easily type, sketch, view and read, whether they're at their desk or on the go. Combo Touch brings versatility to iPad, enhancing the user experience and promoting productivity anywhere.
Four use modes
Combo Touch has four use modes to help you accomplish any task. Adjusting the kickstand allows you to find the perfect angle to type, sketch, view or read -
Your fingers will thank you
Enjoy hours of comfortable typing thanks to large, well-spaced keys stretched edge-to-edge so your hands won't feel crowded. Logitech keyboards feature a scissor mechanism beneath each key to deliver the perfect bounce every time -
Ditch the keyboard
Done typing? Just detach the keyboard so you can sketch, read or watch videos without anything between you and your beautiful iPad Air screen -
Premium trackpad experience
The click-anywhere trackpad gives you more control and more precision to tackle the tasks you perform every day. Use all the Multi-Touch trackpad gestures you already know and love - swipe, tap, pinch, and scroll your way through work -
Beautifully crafted for iPAD Air
The iPad Air meets its aesthetic match with a clean, sleek design-the thinnest keyboard case Compared to Logitech keyboard cases with trackpad released in 2020. we've ever designed with a trackpad. The elegant woven outer fabric feels as great as it looks -
Adjustable kickstand
The ultra-flexible kickstand offers an incredible 50-degrees of tilt so you can always find the right angle for the task at hand. A sturdy mechanical hinge ensures the kickstand stays firmly in place and does not collapse, even with strong tapping -
Secure, form-fit protection
Combo Touch is designed to perfectly fit your iPad Air, protecting the front, back, and corners from scrapes and bumps. This brings a peace of mind so you can focus on what matters-getting things done, no matter where you need to do them -
Type day or night
Backlit keys automatically adjust to your environment with 16 levels of brightness-so you can see your keys and stay focused in any lighting environment. Shortcut keys at the top of the keyboard allow you to manually adjust brightness -
Power and pair in one click
Combo Touch instantly pairs with your iPad Air via Smart Connector. Batteries aren't included, because you'll never need them-power for Combo Touch is sourced directly from your iPad Air -
Supports Apple Pencil charging
Need a quick power boost for your Apple Pencil (2nd gen)? Combo Touch was designed with an open side so you can keep your case on while you charge your Apple Pencil (2nd gen)
- Logitech Combo Touch - keyboard and folio case - with trackpad - QWERTY - UK - oxford grey Input Device
- Keyboard and folio case
- Backlit
- 16-level
- Interface
- Apple Smart connector
- Input Device
- Detachable keyboard
- Connectivity Technology
- Wired
- Built-in Devices
- Trackpad
- Localization and Layout
- QWERTY UK
- Hot Keys Function
- Home screen, brightness, backlight control, dictation, screenshot, media controls, volume, do no disturb
- Protection
- Back protection, front protection, corner protection, scratch protection, scuff-resistant
- Oxford grey
- 22.58 cm x 1.51 cm x 28.5 cm
- 685.9 g
- 2-year warranty
- Designed For
- Apple 13-inch iPad Air (M2, M3)
- Backlit
- 16-level
- Interface
- Hot Keys Function
- QWERTY UK
- Keyboard Technology
- Scissors
- Built-in Devices
- Trackpad
- Protection
- 22.58 cm
- 1.51 cm
- 28.5 cm
- 685.9 g
Carrying Case
- 10°-60° adjustable angles, backlit auto-adjusting, Apple pencil holder, ports and controls access
- Oxford grey
- Limited warranty - 2 years
- Designed For
