The Logitech Combo Touch keyboard case provides form-fit protection for iPad. The Multi-Touch trackpad enables precise navigation and a detachable keyboard offers flexibility for different tasks. Users can easily type, sketch, view and read, whether they're at their desk or on the go. Combo Touch brings versatility to iPad, enhancing the user experience and promoting productivity anywhere.
Take iPad Further
Power your passion from anywhere. Meet the keyboard case that enables whole new levels of versatility and protection. Multiple use modes allow you to easily type, view, sketch, read and more with Combo Touch for iPad Air. Possibilities? Endless -
Thinner. Lighter
The new Combo Touch is the thinnest and lightest yet; it slips into bags, travels light, and powers your productivity anywhere -
Largest trackpad ever
The biggest trackpad ever made for Combo Touch. Familiar Multi-Touch gesture controls let you swipe, pinch, double-tap, and more -
Premium Materials
Thoughtfully designed with sustainable, premium materials that feel as good as they look. Our newly formulated textiles are both beautiful and soft to the touch -
Use-your-way modes
Multiple use modes and infinite possibilities. Switch it up to type, sketch, watch videos, read, or hop on a video call -
Detachable, full-sized keyboard
Large, well-spaced keys give your hands plenty of room to type comfortably, while scissor keys give you that perfect bounce. Done typing? Just detach the keyboard to sketch, watch or read with total freedom -
The precise trackpad provides that superior, intuitive tracking experience you need to make things happen. Familiar Multi-Touch gesture controls let you swipe, pinch, double-tap, and more -
Flexible kickstand
Find your preferred angle for just about any task with the ultra-flexible kickstand -
Secure, form-fit protection
The sturdy and portable case keeps your iPad safe from scuffs and scratches, so you can take it anywhere with total peace of mind -
Type away, day or night
Adjustable backlit keys enable your mood-lit work sessions to be even more enjoyable than ever -
Just connect
Smart Connector technology enables seamless, instant, secure connectivity with no need to charge-it's powered by iPad -
Supports Apple Pencil
Combo Touch is designed to let you attach Apple Pencil right to iPad. No need to remove the case
- Logitech Combo Touch - keyboard and folio case - with trackpad - QWERTY - UK - oxford grey Input Device
- Keyboard and folio case
- Backlit
- 16-level
- Interface
- Apple Smart connector
- Input Device
- Detachable keyboard
- Connectivity Technology
- Wired
- Built-in Devices
- Trackpad
- Localization and Layout
- QWERTY UK
- Hot Keys Function
- Home screen, brightness, backlight control, dictation, screenshot, media controls, volume, do no disturb
- Protection
- Back protection, front protection, corner protection, scratch protection, scuff-resistant
- Oxford grey
- 22.58 cm x 1.51 cm x 28.5 cm
- 685.9 g
- 2-year warranty
- Designed For
- Apple 13-inch iPad Air (M2, M3)
- Backlit
- 16-level
- Interface
- Hot Keys Function
- QWERTY UK
- Keyboard Technology
- Scissors
- Built-in Devices
- Trackpad
- Protection
- 22.58 cm
- 1.51 cm
- 28.5 cm
- 685.9 g
Carrying Case
- 10°-60° adjustable angles, backlit auto-adjusting, Apple pencil holder, ports and controls access
- Oxford grey
- Limited warranty - 2 years
- Designed For
