Logitech Combo Touch for iPad-7th gen
Quicklinx: G2KNWS00 Mfr#: 920-009629
Device Type: iPad 7th Gen, iPad 8th Gen, iPad 9th Gen
Type: Folio Case with Keyboard
Device Screen Size: 10.2
Colour: Graphite
£120.54 ex VAT
£144.64 inc VAT
The ultimate iPad case has just touched down. Combo Touch combines a precision trackpad with a full-size backlit keyboard for your iPad. Navigate iPad with familiar gestures and easily edit spreadsheets, documents and more. Plus, a flexible design supports four use modes for extra versatility.
  • A case you'll really click with
    Meet the keyboard case that enables whole new levels of versatility and protection. Type, view, sketch, and read with Combo Touch and iPad. The large trackpad along with the laptop-like keyboard, allows you to work and create effortlessly. Possibilities? Endless
  • Four use modes
    Combo Touch has four use modes to help you accomplish any task. Adjusting the kickstand allows you to find the perfect angle to type, sketch, view or read
  • Your fingers will thank you
    Enjoy hours of comfortable typing thanks to large, well-spaced keys stretched edge-to-edge so your hands won't feel crowded. Logitech keyboards feature a scissor mechanism beneath each key to deliver the perfect bounce every time
  • Ditch the keyboard
    Done typing? Just detach the keyboard so you can sketch, read or watch videos without anything between you and your beautiful iPad screen
  • Premium trackpad experience
    The high-precision trackpad gives you more control and more freedom to tackle the tasks you perform every day. Use all the Multi-Touch trackpad gestures you already know and love - swipe, tap, pinch, and scroll your way through work
  • Adjustable kickstand
    The ultra-flexible kickstand offers an incredible 50-degrees of tilt so you can always find the right angle for the task at hand. A sturdy mechanical hinge ensures the kickstand stays firmly in place and does not collapse, even with strong tapping
  • Secure, form-fit protection
    Combo Touch is designed to perfectly fit your iPad Air, protecting the front, back, and corners from scrapes and bumps. This brings a peace of mind so you can focus on what matters-getting things done, no matter where you need to do them
  • Type day or night
    Backlit keys automatically adjust to your environment with 16 levels of brightness-so you can see your keys and stay focused in any lighting environment. Shortcut keys at the top of the keyboard allow you to manually adjust brightness
  • Power and pair in one click
    Combo Touch instantly pairs with your iPad via Smart Connector. Batteries aren't included, because you'll never need them-power for Combo Touch is sourced directly from your iPad
  • Home for Logitech Crayon
    A built-in holder for Logitech Crayon or Apple Pencil keeps your digital pencil always within reach so you can easily hand-write notes, sketch drawings, or markup documents directly on iPad
Logitech Combo Touch - keyboard and folio case - with trackpad - QWERTY - UK - graphite Input Device
Keyboard and folio case
Backlit
5-level
Apple Smart connector
Wired
Built-in Devices
Trackpad
Localization and Layout
QWERTY UK
Hot Keys Function
Search, mute, brightness, screen lock, play/pause, previous track, next track, home screen, on screen keyboard, backlight control, volume -, volume +
Protection
Scratch-resistant, spill-resistant, scuff-proof
Graphite
Case Material
Woven fabric
25.7 cm x 19.5 cm x 2.255 cm
610 g
Apple 10.2-inch iPad (7th generation, 8th generation, 9th generation)
Backlit
5-level
Hot Keys Function
QWERTY UK
Built-in Devices
Trackpad
Protection
25.7 cm
19.5 cm
2.255 cm
610 g
Carrying Case
Material
Woven fabric
Adjustable kickstand, ports and controls access, protective corners, auto sleep/wake function, Apple pencil holder
Graphite
Device Type: iPad 8th Gen
Device Type: iPad 9th Gen
Colour: Graphite
Brand: Logitech
