Logitech Combo Touch for Apple 10.9-inch iPad Air (4th/5th generation) - Oxford Grey
Quicklinx: GQ6MWS00 Mfr#: 920-010303
£159.36 ex VAT
£191.23 inc VAT
The Logitech Combo Touch keyboard case provides form-fit protection for iPad. The Multi-Touch trackpad enables precise navigation and a detachable keyboard offers flexibility for different tasks. Users can easily type, sketch, view and read, whether they're at their desk or on the go. Combo Touch brings versatility to iPad, enhancing the user experience and promoting productivity anywhere.
  • Four use modes
    Combo Touch has four use modes to help you accomplish any task. Adjusting the kickstand allows you to find the perfect angle to type, sketch, view or read
  • Your fingers will thank you
    Enjoy hours of comfortable typing thanks to large, well-spaced keys stretched edge-to-edge so your hands won't feel crowded. Logitech keyboards feature a scissor mechanism beneath each key to deliver the perfect bounce every time
  • Ditch the keyboard
    Done typing? Just detach the keyboard so you can sketch, read or watch videos without anything between you and your beautiful iPad Air screen
  • Premium trackpad experience
    The click-anywhere trackpad gives you more control and more precision to tackle the tasks you perform every day.  Use all the Multi-Touch trackpad gestures you already know and love - swipe, tap, pinch, and scroll your way through work
  • Beautifully crafted for iPAD Air
    The iPad Air meets its aesthetic match with a clean, sleek design-the thinnest keyboard case Compared to Logitech keyboard cases with trackpad released in 2020. we've ever designed with a trackpad. The elegant woven outer fabric feels as great as it looks
  • Adjustable kickstand
    The ultra-flexible kickstand offers an incredible 50-degrees of tilt so you can always find the right angle for the task at hand. A sturdy mechanical hinge ensures the kickstand stays firmly in place and does not collapse, even with strong tapping
  • Secure, form-fit protection
    Combo Touch is designed to perfectly fit your iPad Air, protecting the front, back, and corners from scrapes and bumps. This brings a peace of mind so you can focus on what matters-getting things done, no matter where you need to do them
  • Type day or night
    Backlit keys automatically adjust to your environment with 16 levels of brightness-so you can see your keys and stay focused in any lighting environment. Shortcut keys at the top of the keyboard allow you to manually adjust brightness
  • Power and pair in one click
    Combo Touch instantly pairs with your iPad Air via Smart Connector. Batteries aren't included, because you'll never need them-power for Combo Touch is sourced directly from your iPad Air
  • Supports Apple Pencil charging
    Need a quick power boost for your Apple Pencil (2nd gen)? Combo Touch was designed with an open side so you can keep your case on while you charge your Apple Pencil (2nd gen)
Logitech Combo Touch - keyboard and folio case - with trackpad - QWERTY - UK - oxford grey Input Device
Keyboard and folio case
Backlit
16-level
Apple Smart connector
Wired
Built-in Devices
Trackpad
Localization and Layout
QWERTY UK
Hot Keys Function
Search, mute, brightness, screen lock, play/pause, previous track, next track, home screen, on screen keyboard, backlight control, volume -, volume +
Protection
Bump protection
Oxford grey
Case Material
Woven fabric
18.93 cm x 1.71 cm x 25.2 cm
574 g
Apple 10.9-inch iPad Air (4th generation, 5th generation)
Backlit
16-level
Hot Keys Function
QWERTY UK
Built-in Devices
Trackpad
Protection
Bump protection
18.93 cm
1.71 cm
25.2 cm
574 g
Carrying Case
Material
Woven fabric
Ports and controls access, protective corners, auto sleep/wake function, Apple pencil holder, backlit auto-adjusting, 10°-60° adjustable angles
Oxford grey
Apple iPadOS 13.4 or later
Brand: Logitech
