Circle View features our Logitech TrueView best-in-class video experience. Capture everything in razor-sharp detail with full HD, 180° diagonal field-of-view glass optics, and more.
LOGITECH TRUEVIEW BEST-IN-CLASS VIDEO
Circle View features our Logitech TrueView best-in-class video experience. Capture everything in razor-sharp detail with full HD, 180° diagonal field-of-view glass optics, and more -
SEE THE BIGGER PICTURE
An ultra wide 180° field-of-view ensures you keep your eye on what matters without missing what's happening on the sidelines -
SUPERIOR CLARITY
Glass optics and a high-quality sensor with wide dynamic range means you catch every detail crystal-clear no matter how bright or dark the environment is -
ENHANCED NIGHT VISION
Circle View's infrared powered night vision is optimized for full-field visibility and superior clarity in the dark up to 15ft away -
CRAFTED FOR YOUR HOME
Circle View features a stunning design with premium details, including a metal base, matte finish, and a power cable that blends seamlessly with any space -
EASY TO SET UP
Power on the camera, add accessory in the Home app on your supported iPhone or iPad, scan the unique setup code, and go. That's it -
CAN GO ALMOST ANYWHERE
Circle View camera can be placed on a shelf or wall-mounted with ease, and features a weatherproof body that's built to withstand the elements -
UNPARALLELED PRIVACY
The only one keeping an eye on your home should be you. That's why the Circle View camera has both hardware and software privacy features built right in. Plus, the HomeKit Secure Video platform ensures your sensitive video stays encrypted at all times -
TILT TO HIDE
Need instant privacy at a moment's notice? Simply tilt the camera down to instantly shield yourself from view -
SIMPLE TURN OFF
A rear-mounted button immediately cuts off both audio and video, so you're not left fumbling during private moments -
MORE CONTROLS IN APPLE HOME APP
The camera works with Apple HomeKit and supports HomeKit Secure Video for added privacy features, including end-to-end encryption, in-home video analysis, automated recording, and more -
BUILT FOR HOMEKIT SECURE VIDEO
Circle View seamlessly integrates with HomeKit. The camera supports HomeKit Secure Video, enabling you to securely store activity detected by your cameras in iCloud -
END-TO-END ENCRYPTED SECURE VIDEO
Video streamed from your Circle View camera and iCloud is end-to-end encrypted to your devices, so only you and the people you share your Home app with can view it -
SMART PRIVACY
Choose when your Circle View camera can stream and record video using HomeKit. In the Home app, set your Circle View to automatically stream and record activity when you and others are away, and turn off when at home -
iCLOUD RECORDING HISTORY
A 10-day motion-based recording history from your Circle View camera is securely stored in iCloud and available to view in the Home app. You can add one camera to your 200GB plan or up to five cameras to your 2TB plan at no additional cost. Camera recordings don't count against your iCloud storage limit -
RICH NOTIFICATIONS
Receive rich notifications on your iPhone or iPad and play video clips right from the lock screen when activity is recorded by your Circle View camera -
INTELLIGENT DETECTION
Capture the important events in and around your home. Apple TV, HomePod, or iPad running as a home hub intelligently determines when a person, animal, or vehicle is in the video recorded by your Circle View camera before securely storing it in iCloud for you -
APPLE HOME APP
Live view with 2-way audio, and recorded video, from your Circle View camera on your iPhone, iPad, or Mac. Share your Home app with others so they can view too -
HomeKit requirements:
Set up Circle View in the Apple Home app on an iPhone with iOS 13.2 or later / iPad with iPadOS 13.2 or later. For remote live viewing and notifications, activity history, automations and intelligent detections, a home hub is required (HomePod with iOS 13.2 or later / Apple TV with tvOS 13.2 or later / iPad with iPadOS 13.2 or later). A supported iCloud plan to store activity history - one camera on 200GB plan / up to 5 cameras on 2TB plan
- Logitech Circle View - network surveillance camera
- Network surveillance camera - fixed - outdoor, indoor - weatherproof
- Audio
- Yes: built-in speaker, two-way audio capability, built-in microphone
- 6.72 cm x 7.05 cm x 5.68 cm
- 253 g
- Connectivity Technology
- Wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 1920 x 1080
- Motion Detection
- Video Modes
- 1080p
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11a
- Intelligent Assistant
- Siri
- Night vision
- 2-year warranty
- Environmental Parameters (operating)
- -20 °C - 50 °C
- Audio Support
- Wireless
- 6.72 cm
- 7.05 cm
- 5.68 cm
- 253 g
Camera
- Colour - Day&Night - fixed - outdoor, indoor - weatherproof
- Max Digital Video Resolution
- 1920 x 1080
- Motion Detection
- Video Modes
- 1080p
- Infrared LEDs
- 2
- Infrared Distance
- 4.5 m
- Night vision
Lens Construction
- Horizontal Field of View (degree)
- 180
- Network Interface
- Included Accessories
- Swivel mount with tethered 3m cable, wall bracket
- IP64
- Power Device
- Power adapter
Internet of Things (IoT)
- Siri
- Limited warranty - 2 years
- -20 °C
- 50 °C
