The Logitech Webcam C930e features the widest-ever field-of-view in a business webcam - 90-degrees - and is the first with HD 1080p H.264/SVC UVC 1.5 encoding, the excellent technology that frees up PC bandwidth with on-camera video-processing. With pan, tilt and zoom functions and RightLight 2 technology, this webcam delivers the most professional desktop video collaboration experience yet.
GREAT VIDEO IN ANY ENVIRONMENT
Show your best side on every video call, wherever you are. The C930e Webcam features 90-degree field of view, pan, tilt, and 4x digital zoom, allowing you to adjust the frame to fit your environment. RightLight 2 Technology and a precision lens provide sharp video even in low-light conditions -
CERTIFIED FOR BUSINESS
C930e is certified compatible with Skype for Business and Cisco Jabber , and offers enhanced integration with BlueJeans, Broadsoft, LifeSize Cloud, Vidyo, and Zoom -
HIGH QUALITY, LOW BANDWIDTH
Raise meeting productivity with remarkably clear video at all times – even when bandwidth is limited. Optimized for Skype for Business, the C930e Webcam supports H.264 with Scalable Video Coding and UVC 1.5 encoding to minimize its dependence on computer and network resources -
WIDE FIELD OF VIEW
With a generous, 90-degree field of view, C930e can capture teams and whiteboards with ease -
4X HD ZOOM
Zoom in and pan around to crop out distracting backgrounds, perfectly frame you and a friend, or capture the entire scene. The premium image sensor delivers HD quality without jaggies or blur, even when zoomed in -
MOUNTING & PRIVACY OPTIONS
Mount the camera wherever it works best – LCD screen, notebook, or tabletop – with the adjustable clip, or mount C930e on your own tripod instead. A removable shade flips down to assure privacy and peace of mind -
CAMERA SETTINGS
Customize your C930e and access pan, zoom, and image controls with Logitech Camera Settings software for Windows and Mac
- Logitech Webcam C930e - webcam
- Webcam
- Audio
- Yes: built-in dual stereo microphones
- 9.4 cm x 4.33 cm x 7.1 cm
- 162 g
- Connectivity Technology
- Wired
- Camera
- Max Resolution
- 1920 x 1080
- Focus Adjustment
- Automatic
- USB 2.0
- RightLight 2 technology, auto low-light correction, Carl Zeiss optics, USB 3.0 compatibility, 1080p Full HD movie recording, Skype compatible
- 3-year warranty
- Webcam
- Audio Support
- Wired
- 9.4 cm
- 4.33 cm
- 7.1 cm
- 162 g
Camera
- Digital Video Format
- H.264
- Max Digital Video Resolution
- 1920 x 1080
- Digital Zoom
- 4
- Video Capture
- 1920 x 1080 @ 30 fps
Lens Construction
- Focus Adjustment
- Automatic
- Computer Interface
- USB 2.0
- Interfaces Details
- 1 x USB 2.0 - 4 pin USB Type A
- Included Accessories
- Privacy shutter
- OS Required
- Microsoft Windows 7, Apple MacOS X 10.7 or later, Windows 8
- Limited warranty - 3 years
