Logitech C930e Hi-Speed USB HD Webcam
Quicklinx: 8T1JWS00 Mfr#: 960-000972
Interface: Hi-speed USB
Compatibility: Mac, PC
33 In Stock
£91.20 ex VAT
£109.44 inc VAT
The Logitech Webcam C930e features the widest-ever field-of-view in a business webcam - 90-degrees - and is the first with HD 1080p H.264/SVC UVC 1.5 encoding, the excellent technology that frees up PC bandwidth with on-camera video-processing. With pan, tilt and zoom functions and RightLight 2 technology, this webcam delivers the most professional desktop video collaboration experience yet.
  • GREAT VIDEO IN ANY ENVIRONMENT
    Show your best side on every video call, wherever you are. The C930e Webcam features 90-degree field of view, pan, tilt, and 4x digital zoom, allowing you to adjust the frame to fit your environment. RightLight 2 Technology and a precision lens provide sharp video even in low-light conditions
  • CERTIFIED FOR BUSINESS
    C930e is certified compatible with Skype for Business and Cisco Jabber , and offers enhanced integration with BlueJeans, Broadsoft, LifeSize Cloud, Vidyo, and Zoom
  • HIGH QUALITY, LOW BANDWIDTH
    Raise meeting productivity with remarkably clear video at all times – even when bandwidth is limited. Optimized for Skype for Business, the C930e Webcam supports H.264 with Scalable Video Coding and UVC 1.5 encoding to minimize its dependence on computer and network resources
  • WIDE FIELD OF VIEW
    With a generous, 90-degree field of view, C930e can capture teams and whiteboards with ease
  • 4X HD ZOOM
    Zoom in and pan around to crop out distracting backgrounds, perfectly frame you and a friend, or capture the entire scene. The premium image sensor delivers HD quality without jaggies or blur, even when zoomed in
  • MOUNTING & PRIVACY OPTIONS
    Mount the camera wherever it works best – LCD screen, notebook, or tabletop – with the adjustable clip, or mount C930e on your own tripod instead. A removable shade flips down to assure privacy and peace of mind
  • CAMERA SETTINGS
    Customize your C930e and access pan, zoom, and image controls with Logitech Camera Settings software for Windows and Mac
Logitech Webcam C930e - webcam
Webcam
Audio
Yes: built-in dual stereo microphones
9.4 cm x 4.33 cm x 7.1 cm
162 g
Wired
Camera
Max Resolution
1920 x 1080
Focus Adjustment
Automatic
USB 2.0
RightLight 2 technology, auto low-light correction, Carl Zeiss optics, USB 3.0 compatibility, 1080p Full HD movie recording, Skype compatible
3-year warranty
Webcam
Audio Support
Wired
9.4 cm
4.33 cm
7.1 cm
162 g
Camera
Digital Video Format
H.264
Max Digital Video Resolution
1920 x 1080
Digital Zoom
4
Video Capture
1920 x 1080 @ 30 fps
Lens Construction
Focus Adjustment
Automatic
Computer Interface
USB 2.0
Interfaces Details
1 x USB 2.0 - 4 pin USB Type A
Privacy shutter
Microsoft Windows 7, Apple MacOS X 10.7 or later, Windows 8
Limited warranty - 3 years
Compatibility: Mac
Compatibility: PC
Brand: Logitech
