Polished, professional Full HD video calls. The C920S Pro HD Webcam delivers remarkably crisp, clear and detailed images in vibrant colors. HD autofocus and light correction adjust to the conditions to provide consistently high definition, and the dual mics on either side of the glass lens capture the natural sound of your voice.
GREAT VIDEO CALLS. PRIVACY INCLUDED
Make a strong impression in your video conference calls with a diagonal, fixed 78° field of view to perfectly frame you and your space-plus full HD at 1080p/30fps or 720p/30fps. The five-element glass lens captures razor-sharp images and clear colors, while autofocus adjusts smoothly and precisely for consistent definition and fluid video. Flip the privacy shutter closed when you want to be off-camera -
ALL-IN-ONE CONTENT CREATION WITH CAPTURE
Easily create, record, and customize settings with our Capture app. A suite of features lets you fully edit and customize your stream, so you can add transitions and text overlays, customize webcam settings, and more -
HD GLASS LENS WITH PRIVACY COVER
The full HD five-element glass lens and premium autofocus capture razor-sharp, clear images, adjusting smoothly and precisely to provide consistent high definition in conference calls. A convenient privacy cover protects the lens-and your privacy
 - Logitech HD Pro Webcam C920S - webcam
 - Webcam
- Audio
 - Yes: built-in stereo microphone
 - 9.4 cm x 2.4 cm x 2.9 cm
- Connectivity Technology
 - Wired
- Camera
- Max Resolution
 - 1920 x 1080
- Frame Rate (max)
 - 30 frames per second
- Focus Adjustment
 - Automatic
 - USB
- Cables Included
 - USB cable - 1.5 m
 - 2-year warranty
 - Webcam
- Audio Support
 - Wired
 - 9.4 cm
 - 2.4 cm
 - 2.9 cm
Camera
- Max Digital Video Resolution
 - 1920 x 1080
- Digital Video Capture Resolution
 - 720p, 1080p
- Frame Rate (max)
Lens Construction
- Focus Adjustment
 - Automatic
- Horizontal Field of View (degree)
 - 78
- Computer Interface
 - USB
- Included Accessories
 - Privacy shutter, clip mount
- Cables Included
 - USB cable - 1.5 m
 - Limited warranty - 2 years
